Lazer
- Jan 1, 1970
- 0
Hi, I have a project that I am stuck on and would be really happy if I
got a solution.
I have two machines that both have footswitch controls with 1/4" jacks.
The main unit turns on when the pedal is pressed and off when it's
released. The second unit turns on when the pedal is pressed and off
when it's pressed a second time. What I want is an adjustable splitter
that accepts one footswitch and has leads that plug into both units. I
want both units to turn on together and when the pedal is released I
want the main unit to stop and the second unit to stop after a time
delay (variable from 1-10 seconds). Also, if the pedal is pressed again
before the second unit has stopped, I want both units to be on and the
second unit's off-delay restarted when the pedal is released.
I've played with some 555 timer circuits and relays, but can't figure
this out. The voltage on the pedals is low (<24).
I need help!
Anyone know a circuit that could be a solution to my problems?????
got a solution.
I need help!
