I
ibbotsnm
- Jan 1, 1970
- 0
elfe111 said:Hi ibbotsnm
have or had the same Problem with my M50
does anyone have an idea how to align those 3 trays?
The most likely way is: tray 3 is in the turntable and the mechanis
is
down
tray 2 is above tray 1 - both in the front part of the drawer
these trays have to be bent a lot if you reinsert them into the drawer
so
that the teeth on the one side, do not turn the teeth on the rotating
mechanism or rather move them into an unwanted position. The mechanis
is
on that side where the teeth on the trays are.
I have managed to open and close all trays but getting the tray 3 ou
of
the turntabel still causes problems with tray 2 - hope to solve thi
by
ading some grease or oil to the mechanism
have luck
Richard
Richard
Hi Richard
I have obtained the repair manual from a company here in the UK an
have recently tried to re-align the trays.
Firstly the manual although helpful in listing the various parts etc.i
loses a lot in the translation from Japanese to English. I think yo
are absolutely correct in your assumption that the trays are arranged
It is probably necessary to fully dismantle the CD assembly from th
rest of the unit first before any realistic repairs can be carried out
I have a copy of those instructions if you require one. My proble
was that the initial snarl up was because of one of the two sprin
mechanisms that elevate the disc in the drive position had itsel
miss-aligned due to a small part of the plastic breaking. This
repaired and after quite some time I managed to understand th
'Carousel' action of the mechanism. By rotating the small bevel gea
(the white one that drops loose when the unit is disasembled)
complete turns the first tray (Tray 2) is made to traverse from th
rear to the front of the unit. Place tray 1 into the rear of the uni
and turn the gear a further 5 turns and it should travel from the rea
to the front as did the first tray, at the same time the first tray i
elevated up to the top front position. the tray will need a littl
assistance during this operation since it normally works the other wa
up and relies on gravity to lift (drop) the tray into position.
similar operation is followed by tray 3 so allowing tray 2 to take ove
the drive position. I also found that the gears didn't rotate fully fiv
times the second time but jammed causing the whole mechanism to foul up
I managed to cure this by disassembling the whole gear mechanism an
turning the 'black gears' to a slightly different position from where
was then able to rotate the whole mechanism freely. Although i
appeared to work when operated by hand, once I had reassembled th
whole unit it refused to operate fully under power. Thats where
stand at the moment. No longer jamming but not yet fully aligned.
will crack the problem yet.!!!
Let me know how you do. I will copy the written procedure if yo
require it.
regards Norman Ibbotso
