Desolder Motorola Components
I repair Motorola 2-way radios and am having difficulty desoldering
some of the components. For example, when desoldering a 6-pin channel
select switch, the outer pair of legs are removed easily. However, the
solder does not flow on the center pair of legs. I have tried
increasing the temperature and flux.
Any suggestions?
Thanks!
Travis Jordan
Any suggestions?
The switch pins may be using 'through hole' connections.
Have you tried a desoldering iron with vacuum pump?
Doug
Since the old switch is bad cut the legs off and remove one leg at a
time.
If you cant get to the legs break the switch with pliers or vice grips.
Doug
maxfoo
Any suggestions?
Thanks!
Use a hot air gun, silly...
Clifford Heath
Any suggestions?
A technique I've used with SM ICs is to poke a fine
wire under all the pins on one side, and solder the
end down to a nearby pad or via. Then apply heat to
the pins while pulling sideways on the other end of
the wire, which lifts the pins one by one.
John Woodgate
I read in sci.electronics.design that Clifford Heath
It would work better if the wire didn't take solder, such as a fine
Nichrome or stainless steel wire. Of course, you have to loop it round
something to anchor the end. Dig out your old wire recorder!
