Determine Power Supply Requirements for Simple Circuit
wyred451
Nov 23, 2018
I would like to build a circuit consisting of a power supply, flashing light, and a reed switch. The purpose of the circuit is for the light to flash when the door the reed switch is connected to is opened. The light is rated for 12 volts and a current of 120 +/- 15 mA. How do I use that information to determine the voltage and amperage requirements of the power supply. I'd like to use an existing power supply such as USB charger and customize it for my needs.
Thank you in advance.
You need a 12V supply capable of at least 120 ma. To avpid stressing it, use pne that can supply 150 ma or more.
If you want to use a USB charger, ypu wpuld need a boost converter to 12V, unnecessarily complicating the project.
The 5V supply would need to be capable of about 450 ma or more, allowing for the boosted voltage and inefficiency.
Minder
Apr 24, 2015
3,561
Usually 12vdc Wall-Wart's are plentiful, less work than converting the 5v, IMO..
M.
kellys_eye
Jun 25, 2010
6,512
Get hold of a flashing red LED (they do exist) instead of the 12V lamp and then you can use your USB charger.
