Device to show when phone is in use
Andy Petro
Bell used to sell a device that told you when a phone was connected.
You placed it in series with the line and a light would indicate when
the line was busy. Any idea as to how to build one as they are no
longer sold.
K
Ken Taylor
longer sold.
Search on "telephone in use indicator". Plenty of circuits and ready-mades.
Ken
Joe G \(Home\)
****** Warning Some Countries forbid connection of non-government approved
telephone equipment OR tampering/tinkering with telephone line ****
*** If info is for educational purposes only ******
1st Understand the concept of phone not in use and hung-up.
How do you detect a phone is off hook.... what happens to the electrical
signals? Ask yourself those questions.
When the phone is on-hook (hung up) the phone has a higher DC resistance...
as if it were not connected....
When the phone is picked up a lower DC resistance is applied by the hook
switch to the phone line.
The lower DC resistance has 2 effects
1. Draws current from the phone exchange typically 20mA to 90mA depending
on how far from the exchange
2. The voltage drops from typically 48 volts to typically 6v ~ 18v
depending on how far you are away from the exchange.
OK.... you how have two effects you can measure....
current ... which requires a series in-line device
voltage.... measure the voltage across the phone point.... parallel circuit.
NOW.... when you measure electrical signals you should not effect the item
you are measuring.
So a series current or parallel voltage measurement is required.
Note... there are other complex factors involved..... but this info may
partly explain the DC characteristic of phone and exchanges.
JG
F
Fred Bloggs
longer sold.
The indicator circuit is required to present an ultra-high impedance to
the line when on hook. This little flasher from Tech-Lib does the job:
View in a fixed-width font such as Courier.
.. +-------+------+|<|-[180]-+
.. FWB | | | + |
.. TIP ---|~ +|--------+ [1M] [1M] | 9V ---
.. | | | | | | Batt |
.. | -|>|- | [22M] | | 1U | |
.. | | 0.01U| | | | + | |
.. RING---|~ -|--+-||--+ | | | | |
.. +-------+ | | | | e | |
.. | [22M] c | |/ | |
.. | | |/ +-----|2N4403 | |
.. | +--|MPSA-18 | |\ | |
.. | | |\ | c | |
.. | | e | | c |
.. | [1M] | [2.2M] +----|2N4401 |
.. | | | | e |
I
Ian Stirling
