V
Veronica Matthews
- Jan 1, 1970
- 0
Dear newsgroup community,
recently I came across the following challenge. There are several digital
values which I want to convert to analog signals. Ok then, no problem.
Simply D/A conversion! But after converting the signals the general set up
requires that these values should be held for about - let's say - a period
of 5 minutes with practically no droop (decay of the analog value) at best!
The D/A conversion itself takes place in a 1 MHz period, the values to be
set have to pend for about 5 minues. I guess a hold-element (capacitor and
op-amp) would be the obvious choice. But how should I dimension the
capacitance and how can I affect the droop? Is it realistic to expect
virtually no droop assuming an optimal configuration ? Isn't it, that with a
large time constant the charging time would be endless, too? Please help me,
if you can. I am almost become desperate. I need this for my graduation
report.
Thank you in advance and many greets
Veronica
report.
Veronica
