never mind. i see the utility of "biplexing" now. i was thinking 7 seg
outs, not 14. but if that's the case, they're trading 4 anode drivers
We'd better substitute "digit" for "anode" here to be more general and
accurate.
for 7 more segment drivers. so i'm back to "why in hell..."
It's actually 13 outputs for the segments and zero for the digits vs.
11, so two more outputs total. (plus colon, alarm announciator(s) and
AM/PM LEDs). 3.5 drivers per digit except for the MS digit which
requires only 2.5 if you parallel segments A and D and leave out F
(the MS digit only has to display blank, 1 or 2 for 24-hour time).
Okay, those segments might be a little less evenly lit due to Vf
variations, but only between 10:00 PM and midnight for those who
choose 24-hour time.
something i'm not visualizing. maybe a spec sheet will help. i'm just
curious.
Do a web search for a clock chip datasheet if you're really curious.
16 pins total (out of a 30-pin shrink-DIP) to drive a 4-digit time
display plus two colon LEDs (paralleled), two separate alarm
annunciators, and AM and PM indicators (6 additional LEDs total).
The biplex input signal comes for free since it's required for the
timebase anyhow.
If you drove that conventionally with standard multiplexed displays
you'd need 7 segment drivers plus 5 digit drivers or 8 segment drivers
plus 4 digit drivers. And an extra center-tapped transformer winding.
So far it doesn't look good, right?
With the conventional way, the digit drivers would each have to be
powerful enough to handle as many as 7 or 8 segments on simultaneously
at 25% duty cycle (maybe 150mA each) vs. the biplex segment drivers
which only need handle around 10mA each for the same brightness. But
the cool thing is that you don't need a bulky filter capacitor for the
150mA power supply, and you don't need any regulation for any of the
LED current (which roughly halves the size and weight of the power
supply transformer) and you don't need to worry about visually
annoying beat frequencies between power supply ripple and the mux
frequency, since it's synchronous. AND since clocks are often combined
with radios, you don't need to worry about LARGE fast-switching
currents to the display causing RFI on the AM frequencies. This design
transitions gently with the mains waveform. Of course the chip pinout
is designed so that a single-sided board is possible/easy.
In reference to the OP's question, the min/max frequency at the
50/60Hz pin on the part I'm looking at is rated at 1Hz ~ 2000Hz. Below
1Hz it switches to the RC oscillator (external R & C) as backup. The
2000Hz limit may be created by the 4800Hz (nominal) RC oscillator and
some logic as a method of further filtering the timebase input from
transients on the mains (they suggest an RC input filter and there's a
ST input).
Best regards,
Spehro Pefhany
