O
Olaf Marzocchi
- Jan 1, 1970
- 0
Hi to all,
I'm building an audio amplifier with the TA202 chip (it's simple to
solder at home and sounds great) for home use.
I'd like to use a digital potentiometer as volume control and a digital
switch to select the inputs (4 way will be enough).
My problem is that I'm a bit inexperienced, so I don't know how to put a
pot like DS1802 (audio pot from Maxim) in the circuit Tripath shows in
the datasheet.
I'll try to draw the circuit here, if it's not clear this is the link:
http://www.tripath.com/downloads/TA2020.pdf.
OUTSIDE | INSIDE
+- R2 --|OP-AMP OUT
input --- C -- R1 -+-------|INV
V \______/
AC, maybe L---> high pass filter: no more DC
with Dc
bias
Inside the chip there is an opamp that takes INV and a constant signal
as input, it's output is the OP-AMP OUT (obviously, OP-AMP OUT is only a
feedback, not the only output).
OP-AMP OUT------+
INV---| \ |
| \ -----+---amplification
2,5V--| /
The TA2020 gain is: constant*R2/R1.
(I hope not to write obvious things).
The digital pot does not allow AC inputs/outputs, so I cannot put it
instead of R2, since it is connected to R1 on one side and in R1 flows
an AC signal.
How should I modify the circuit? I'd like not to put the digital pot
simply after R1, since it would change the high-pass filter and it would
attenuate the signal (less dynamic range), not set the gain.
As far as it concerns the audio input selection, I think I will read
what is already available in sci.electronics.* before asking. However, I
will probably have the same problem: the switch will accept DC inputs
while I have AC inputs.
Thank in advance to anyone! I hope to be able to build my hi-fi soon! (I
have already designed the circuit board, the gain and the switches are
the only things left).
Olaf Marzocchi
the datasheet.
OUTSIDE | INSIDE
+- R2 --|OP-AMP OUT
V \______/
with Dc
bias
OP-AMP OUT------+
INV---| \ |
2,5V--| /
an AC signal.
Olaf Marzocchi
