Meek the Geek
- Jan 1, 1970
- 0
Hi, My name is Mike, I'm a mechanical engineering student
I'm building a digitally controlled electromagnet for a project,
the system needs to be controlled between 0V to 24 Volts DC with up to
4 Amps of current and I do not think that PWM will be a suitable
control on this devce for a variety of reasons (it gets complicated,
but trust me though, no PWM).
I found a design on a website for an adjustable power supply, and
given that for the purposes of experimentation we will be using a
lab-bench DC power supply set to provide 30V DC power, and then
regulate that current. It means that we can eliminate the transformer
and bridge rectifier for now. The design I am proposing involves using
a digital potentiometer to replace the manually controlled
potentiometer shown in the design below
http://www.aaroncake.net/circuits/supply.htm
My problem right now is that the digital potentiometers that I
have seen seem to be limited to only 5VDC. At the voltage which I
intend to use, I am very sure that I will be blowing it up when I reach
certain voltage levels. Is there a way of buffering the digital Pot
such that I can avoid barbecuing it, while still being able to use it
to provide digital power control. I was provided with an x9c103
digital potentiometer from Xicor/Intersil (10K Ohm, with 100 wiper
positions) http://www.intersil.com/products/deviceresults.asp?i=10763
Is there a simple way to buffer this digital Potentiometer (use
OP-Amps, a transistor, magic faerie dust) so that even though it only
has a 5 Volt survival range, I can use it to control the larger
voltage?
Thanks in advance
voltage?
Thanks in advance
