digitor tv g5151
phil
went dead and now no power, fuse o.k. any clues which components ??
JANA
Your question is extremely vague. It is something like, "My car will not
start. I changed the main starter fuse...".
There is too much involved for any reasonable explanation. Start by
verifying the voltage outputs of the power supply, and its distribution
through the set, to the vital areas to make it start up. Then verify the
performance of the scan generator, the HV circuits, and then scan circuits.
This is only the basic start.
Servicing TV sets is a specialized job requiring experience, the proper
tools, training, and service information. You would be best off having an
estimate done for your set. If the set is a low cost one, consideration of
replacement may be the best decision.
There are serious safety issues when servicing TV sets.
JANA
_____
Russ Verdon
I repaired a digitor G5 something recently rescued fron the kerbside.
It had a few dry soldered joints which brought it back to life.
Have a really close look at the soldering on the cctboard and resolder
anything
that looks dodgy. It may just work.
Also just fixed a discarded 68cm LG with one bad joint at the power
connector to the mainboard.
It's a shame to see these going to the tip.
Russell
