Diode panasonic part number or info on D867 in Viewsonic 21VS001.
Jason D.
Finally found this diode. not brust open or burnt, more like
physically cracked in two and for some reason other half was rotated
180 degrees that broken edges doesn't meet and still original
soldered. Wow.
D867 is in series with D861 off the 200V pin on the output of SMPS
transformer. D867 has printings that I can't identify. I need the
max current and voltage and type of diode it is used or part number
for this diode from Panasonic so we can order one from Panasonic.
Thanks & Cheers,
Wizard
Steve
soldered. Wow.
You may find the schematic you need here:
http://www.wimtv.be/techniforum/login.php?redirect=viewforum.php&f=10&start=0
Hunt around, there are several monitors from different manufacturers
sharing the same basic (Panasonic) chassis.
