disapointed with 3000 watt inverter
Survivalbill.com
well got my new 3000 watt inverter setup and was so happy I could now run my
500 watt microwave ya for like 7 seconds and that was it! the 2 trojens 225
ampers? went from 13 volts down to 11 volts in 7 seconds oh man I just
calculated I would need 257+ trojens to run the microwave for 15
minutes...the gas generator was cheep compared to what I now pumped into
solar panels inverter batteries now looks like more batteries OH my!
I know that that is not supposed to be the case so what's up!
t105s are a year old and were at full charge at the time ok I may just have
been underpowed so how many of em will I really need to run that microwave
for 15 minutes that's my goal in life at the moment and I don't want to
spend the $ 27,000 on t105s as it looks like that's the case at the
moment....
_____________________________________
Survival Bill Outdoor Retreat
Website: http://www.survivalbill.com
Message Forum: http://www.survivalbill.com/phpBB2/index.php
Photos: http://www.survivalbill.com/photosa.htm
Store: http://www.survivalbill.com/phpBB2/portal3.php
Emergency Alert System: http://www.survival.com/alarm/on.htm
W
William P.N. Smith
Survivalbill.com said:
3000 watt inverter
What else have you got, and how is it wired? Note that a 3KW inverter
at 12V will draw something like 300 amps, so you are going to need
some pretty heavy duty and short wiring between the batteries and the
inverter.
Just a single pair of T-105s? They are rated at 75A drain in a golf
cart application, and 150-ish amp-hours at that rate, you are doing 4X
that, so I'd be surprised if you got 15 minutes out of them.
I'd put four pairs in parallel (*) and try again. Then they ought to
run your microwave for a couple of hours. Four hundred dollars worth
of batteries.
(*) Actually, I'd wire them for a 48V inverter and get the current
down by a factor of four, but you've already bought your inverter, and
that had to cost your $3K...
Also, tell us about your charging setup...
inverter.
But, only if you are are drawing the full 3kw. Otherwise, ignoring
inefficiencies, you should consider the load as the 500 watts, which
he said the microwave draws.. that is more like 42 amps, less than the
golf cart and should last more like 3 hours at 150-ish amp hours.
Ecnerwal
Measured where? At the battery terminals, or at the inverter? I suspect
a bad connection which is not handling the current. Something in the
0.05-0.025 ohm range would just about do that, based on estimates of
your likely current draw at between 40 and 80 amps.
You do need considerably more detail to get useful help, which will be
offered if useful details are provided.
Bob Adkins
I run my 1500W inverter from a 115Ah trolling motor battery. I often vacuum
for 20 min. with a 13a shop vac and run an air compressor that draws 13a or
more. Both the battery and the inverter hold up fine. Sure, there's a
temporary voltage drop in the battery, but it doesn't sag low enough to kick
off the inverter. I have short heavy wiring from battery to inverter, and it
still gets a little warm.
Either your wiring is too thin or too long (in which case it will get hot)
or your microwave is pulling far more amperage than it should. Or... those
Trojans are, er... I hate to say it... :(
Remove "kins" to reply by e-mail.
