K
Klaus Kragelund
- Jan 1, 1970
- 0
Hi
The standard RS485 drivers available has a minimum voltage of 3V and a rarther large drop voltage when loaded with the defined bus load for Modbus of 54ohms, and this causes problems for our design since we have limited power available for driving the bus
So, we are thinking about designing our own driver in discrete components, so we can reduce the supply down to 2V and still comply with minimum 1.5V differential voltage into 54ohms.
We only need 115k baud, so we could use a tiny logic level FET as the output stage. Shortcircuit protection would be done with a current limit circuit along with a low value supply capacitance (to reduce peak power in the FETs)
Backfeed would need to be solved with a beefy diode to a defined clamp voltage.
So, anyone been down this road, designing your own RS485 driver?
Cheers
Klaus
Cheers
Klaus
