discrete opamp current sources?
John Larkin
Found this discrete audio type opamp from 1977
http://es.geocities.com/mart_in_medina/918opamp.jpg
Question
The designer used two sets of diodes for setting the bias for Q3, Q4
I would normally just use 2 diodes common to Q3, Q4
What's the advantage in using 2 sets of diodes?
martin
There's probably a latchup mode. If they shared and the output rails
high, Q4 could saturate and steal all the bias from Q3, turning off
Q6-Q7, and it's dead forever.
Old original LM324s suffer from shared bias supply problems, but at
least they recover.
John
Robert Baer
Question
martin
You forgot Q5...
Better to use matched transistor pairs in same package (for better
thermal coupling), and use a resistor in place of that "extra" diode
where the resistor matches (in value) that used for Q3, Q4 and Q5.
martin griffith
least they recover.
John
Thanks, I'd hadn't thought about fault conditions, maybe I'll
LTspiceit, and see if that happens, but I still dont trust (LT)spice
for wierd stuff, but thats probably just my ignorance
martin
H
Helmut Sennewald
Question
martin
Hello Martin,
If the opamp is driven near saturation (Q6 off), a lot of
current will flow into the base of Q4 and thus lowering the
voltage across the two diodes. This would be a large
unwanted change in the current for the differential input stage.
The base current of Q4 will also change in the normal
operation with every change of the output voltage.
This will modulate the bias current source of the input
pair too. Think on additional distortion here.
Over all two good reasons for seperate bias voltages.
Best regards,
Helmut
John Larkin
martin
The three 27K resistors could be reduced to two.
The input diodes prevent another latch mode, zenering an input b-e
junction. It may have some other hazards if connected as a follower.
John
Tony Williams
Question The designer used two sets of diodes for setting the
bias for Q3, Q4
Probably to avoid a latchup if the -IN voltage ever
gets high enough to bottom Q3. With joined bases the
Q4 cc-source would then suddenly change current.
