Dishwasher Control Board Repair
mendit
Nov 11, 2015
I am trying to repair my non-functional dishwasher and I have found a component on the control PCB that has partially burnt and disintegrated. It is a surface mount item with the markings: ST Z3M A009. It has 3 pins on one side and one longer tab on the opposite side.
I would be very grateful if someone could tell me where to get this component or an equivalent in the UK please.
I have virtually no electronic knowledge but to have the soldering skills to replace the component.
Many thank in anticipation.
73's de Edd
Aug 21, 2015
3,730
Sir mendit . . . . .
I read the coding on the device as:
ST electronics being the manufacturer of that device
The actual full device number id is . . . . Z0103MUF
The A009 is being a code date.
This Triac unit specs out as being a 600V 1 amp unit with a gate sensitivity of 3 ma.
Mouser has 2,906 in stock at 84 cents a copy . . .OR . . .
do a search of UK suppliers using the full
Z0103MUF
numbering of the part.
Da Da sheet :
http://www.mouser.com/ds/2/389/CD00002268-310792.pdf
73's de Edd
dorke
Jun 20, 2015
2,342
Please post the Brand and Model of your dishwasher.
That way we can be of help:
finding the service manual and guiding you further.
Electronic parts "blow-up" because of some reason,
many times not just a single device with visible damage.
Finding the reason is the way to fix,not just replacing a "blown" device.
"no electronic knowledge"
not a very good point to start with electronic repair...;)
