Do I need resistors with my transistor?
Mat17
Oct 13, 2015
23
I'm going to to use a 12V battery (with Solar Panel) to power an Arduino AND a 12V solenoid. I will use a transistor to switch the solenoid on after a digital output is sent from the Arduino.
The circuit will be similar to this raw design here, (minus the relay, and the motor is a solenoid).
Also, I have no idea about the 1K resistor or what value it should be. It was just a raw schematic from something else.
P.S. I also know I will need capacitors for the 7805l
hevans1944
Hop - AC8NS
Jun 21, 2012
4,986
.. The circuit will be similar to this raw design here, (minus the relay, and the motor is a solenoid). ...
If you intended to upload a schematic diagram or image, try again. It didn't work.
Minder
Apr 24, 2015
3,561
If driving a solenoid from an Arduino look at a Fet such as 2n7000.
If over 200ma load then a logic level power mosfet will work.
M.
Minder
Apr 24, 2015
3,561
That is the advantage of a Fet, It is voltage and not current driven.
M.
Mat17
Oct 13, 2015
23
Arouse1973
Adam
Dec 18, 2013
5,178
If you tell us the spec of the solenoid and what transistor your using I am sure we can work something out.
Cheers
Adam
For a saturated switch, my rule of thumb is base current 10% of collector current.
Collector current is what the solenoid draws. Call it Is.
Then it is simply Ohms law from there. The voltage across the base resistor is the voltage you apply to it -0.6V, the approximate Vbe.
So:
Ib = Is / 10
V = I * R
(Vin - 0.6) / Ib = R
