Do multimeters "wear out" after so many years? Fluke vs. Ideal, Wavetek??
Noticed that old Fluke meters are selling for $50-$80 whereas
comparable Wavetek meters, same features, sell for $10-$30.
Any suggestions on whether the extra cost of a used Fluke is worth it,
over Wavetek?
Also, is the Ideal multimeter really a Wavektek? (Buttons are in the
same position, same functions.) But, why cheaper?
I have 2 8060A meters, an 8050 and 8000. The 8060As are the work
horses. Very reliable and tough to break. Only problem with one after
15 years was the MAC chip (40 pin A/D and switching came partly
unplugged and died) Fluke no longer repairs these and no parts are
available. Got a broken one on eBay, which had a good MAC chip and all
is well. I've used Waveteks at work and they're OK but I want my Fluke.
GG
James Sweet
over Wavetek?
It's more a matter of reliability, durability, accuracy and serviceability.
Meters don't so much "wear out", rather they tend to get zapped by excessive
voltage, dropped, crushed, banged around, and calibration drifts with age.
Just about anyone in the electronics field will tell you to get a Fluke.
That said, watch out for some of the new low end Fluke stuff, it's made in
China these days.
philo
over Wavetek?
although i've used fluke's for years...
the last time a got a meter it was a wavetek
it had more features than the fluke and cost less...
it's been running fine for many years and i use it in a very rough
industrial application
my guess is that if both a fluke and a wavetek were dropped from a great
height...the fluke would prob hold up better...
but the wavetek is a good meter
F
Franc Zabkar
.... except me. I have a PM97 Scopemeter which cost me AU$2750 but
which has been a POS from day one. Just get yourself a cheap DMM and
calibrate it against a 5.000V reference.
See this simple calibration circuit based on a MAX6350 5.000V
reference IC. This chip has a claimed 0.02% accuracy (5.000 +/-
0.001V):
http://www.siliconchip.com.au/cms/A_30853/article.html
China these days.
- Franc Zabkar
Rifleman
You are so right, there is lot's of good DMM,s on the market for less price
than FLUKE but those FLUKE are good. I got 2 FLUKE 77 and I had them for I
don't know how long maybe 15 years or more and they never seem to wear out.
Even if you are a PRO you even try to measure high voltage with the range
knob at ohm :)
I've done this and they are still ok.
Bjorn
melosenoway
Rifleman said:
"philo " "philo "@privacy.net skrev i meddelandet
[email protected] wrote:-
it,
over Wavetek?
great
but the wavetek is a good meter-
price
for I
out.
range
knob at ohm :)
Bjorn
Buy a Fluke....if your serious about reliability...
Mark D. Zacharias
My Beckman 223 died suddenly the other day.
Wa-ah!
I tried to turn it on, nothing. Hmmm. Had a fresh battery, I thought. Opened
it up. Battery was fairly warm. Main processor IC, however, was almost hot
enough to burn my finger.
Darn shame - it was a good one for 15 years or so.
Limping along with a Radio Shack meter 'til I decide what to buy.
Mark Z.
Dave Plowman (News)
Opened it up. Battery was fairly warm. Main processor IC, however, was
almost hot enough to burn my finger.
I had a trusty old Maplin (chain similar to Radio Shack?) blow up when
measuring 240 volt AC. On opening it up, the cause was brass dust from the
slip rings bridging tracks. And since it was rarely used on high voltage
stuff it was ok until then.
All it took was a couple of transistors - which of course had house
markings only. Replaced them with a guess and re-calibrated it and it's
been ok for none critical stuff.
But treated myself to a Fluke 179 which is super. In the UK it costs
about 200 gbp. Bet it's half that in the US. ;-)
Sam Goldwasser
Wa-ah!
My Lafayette VOM is about 35 years old and still going strong. It has
a needle. :)
--- sam | Sci.Electronics.Repair FAQ Mirror: http://repairfaq.ece.drexel.edu/
Repair | Main Table of Contents: http://repairfaq.ece.drexel.edu/REPAIR/
+Lasers | Sam's Laser FAQ: http://repairfaq.ece.drexel.edu/sam/lasersam.htm
| Mirror Sites: http://repairfaq.ece.drexel.edu/REPAIR/F_mirror.html
Note: These links are hopefully temporary until we can sort out the excessive
traffic on Repairfaq.org.
Important: Anything sent to the email address in the message header above is
ignored unless my full name is included in the subject line. Or, you can
contact me via the Feedback Form in the FAQs.
K
Ken G.
I got a Fluke 83 brand new . It has seen little use and sits in a drawer
in my desk & gets used a bit still & still looks like new .
the problem it has is .. when i turn it off it makes strange clicking
sounds till i move the switch on then back off . many times when i turn
it on it is on some wrong range , once again moving the switch one range
then back clears it up .
I have taken itapart & cleaned the switch and checked for loose solder
e.t.c. & never found the problem . I took it to or local Fluke dealer
repair center and they could not get it to act up .
Dave Plowman (News)
a needle. :)
But if a high impedance input, presumably a valve type so mains operated?
I love - and collect - old test gear, but the fact remains that you'll get
modern equivalents which fit in the hand, rather than the bay, which are
more accurate and work off a battery. ;-)
James Sweet
I just checked, they're available over here for about $200, so yeah, almost
exactly half. I would guess one could be ordered from a US supplier? I know
a number of those places will ship overseas and I imagine you'd still come
out ahead even with shipping.
Mark D. Zacharias
a needle. :)
I have an Eico I built in tech school which has a large analog meter.
20kOhms per volt. Measures a bit too high on DC voltages. Always have to
switch leads around to measure different polarity voltages. Have to
interpret readings of several dial scales, etc. Too lazy for this anymore.
Just give me a good digital!
Mark Z.
Sam Goldwasser
No, 30,000 ohms/V, no active components, ohms use a battery.
The Lafayette get's used daily; my Fluke 89 usually stays in the closet.
For a lot of things, accuracy isn't the main criteria.
Dave Plowman (News)
That's good for an analogue meter. The UK equivalent would be the good ol'
AVO Model 8 which only manages 20k ohms/volt on DC, but also lasts forever.
Indeed, a low input impedance meter has a lot going for it in many day to
day measurements. And of course a swinging meter needle can often tell
more than a digital readout. And is very difficult to blow into the middle
of next week. ;-)
Sam Goldwasser
of next week. ;-)
This Lafayette appears to be very well protected. I've done numerous
stupid things with it and the only casualties have been a couple blown
resistors and a blown trace on the switch PCB. The meter itself was
never affected.
N
NSM
of next week. ;-)
I used a DVM to check for leakage on an AC line and got false readings. A
'real' meter worked better.
James Sweet
I much prefer digital for day to day work, though analog meters are still
clearly superior for certain uses. I suppose it's kinda like manual
transmissions in cars (which I very much prefer) though the rest of the
world seems to be lazy and want an automatic but to each their own.
Dave Plowman (News)
A 'real' meter worked better.
You could, of course, simply use a parallel resistor to bring a DVM more
into line with a needle type. Something like 240k ohms for 240 volts.
