Does anyone have a simple UART-based P-S, S-P design?
Lasrsmith
Hello group,
I'm working on a small project that has 8 lines of parallel data that I'd like
to convert to serial, transmit and convert back to 8 lines parallel. Does
anyone have a hardware-only circuit using UARTs, shift registers, etc., without
the need for any software programming? I'm trying to help a friend out on this
project and he doesn't want to program a stamp, processor, etc.
Thanks in advance
Bill Sloman
Hello group,
like to convert to serial, transmit and convert back to 8 lines parallel.
Does anyone have a hardware-only circuit using UARTs, shift registers, etc., > without the need for any software programming? I'm trying to help a friend > out on this project and he doesn't want to program a stamp, processor, etc.
You don't say what sort of speed you want, how long your serial line
is, or what sort of serial link you plan to use.
One - possibly over-kill - solution might be the National
Semiconductor low voltage differential signalling (LVDS) serialisers
and deserialisers.
http://cache.national.com/ds/DS/DS92LV1021A.pdf serialiser
http://cache.national.com/ds/DS/DS92LV1212A.pdf deserialiser
http://www.national.com/an/AN/AN-1238.pdf application note
You connect both chips to the same 16 to 40MHz clock, and they
multiply it internally by twelve to transmit ten bits of data across a
balanced serial link at the input clock rate. The data rate can go up
to 480Mbit/sec, so the serial link can't be too long or too
dispersive.
petrus bitbyter
Lasrsmith said:
Hello group,
Thanks in advance
Lasr,
Elector ever published a converter like that, meant to send parallel printer
data via a serial line. It may be hard to find a stand alone UART these
days. The last one I ever saw was a HD-6402 from Harris. Don't know whether
it's still available. I ever designed a UART from scratch, using a PROM to
control it. Whether you like it or not, the modern way to build this
function is using a micro with a build-in UART.
pieter
W
Wouter van Ooijen
Your post tickled me, I'll make a kit for this. It will use two
PICmicro controllers, but they will be pre-programmed. But making the
(small) PCB's for it will take some time. If you are interested in
being the guinea-pig (first user) let me know by email.
Wouter van Ooijen
http://www.voti.nl
PICmicro chips, programmers, consulting
W
Wouter van Ooijen
If fact I programmed a solution last night. Just two programmed IC's
(PIC16F630, 14-pins), one as sender and one as receiver. Add two more
chips (75179, 8-pins RS-485 interfaces or something similar) if long
distance and/or noise immunity is needed. If the original poster is
still interested he can have a set (in exchange for his experiences).
Wouter van Ooijen
http://www.voti.nl
petrus bitbyter
Pieter Hoeben said:
I know that a loing time ago there has been something like this
in Elektor (Elektuur in the Netherlands), but I don't know
where and when.
Regards,
Pieter Hoeben
In the Netherlands it was the october 1984 issue.
pieter
W
Wouter van Ooijen
Is it strobed (8 data inputs and a clock) or is it just reading
the input, and sending it to the other end, as often as possible?
Does the protocol have error correction/detection of some sort?
Just trying to tickle you a bit more ;)
At the moment: sends as often as possible, no error checking. Both
could be done. Note: it does *not* use the standard asynchronous
protocol, because that is not very reliably been two PICs on internal
clock.
Wouter van Ooijen
http://www.voti.nl
F
Frank Bemelman
clock.
And the F630 having no UART, it would make it lot more comlicated
too, so a self-clocking datastream is easier to handle as well ;)
Still, it is a nice gadget, since it can be made with this cheap
convenient components.
F
Fred Bloggs
clock.
Wouter van Ooijen
http://www.voti.nl
What protocol does it use?
Byron A Jeff
Hello group,
Just a stream of conscientiousness here:
1) The hardware shown in this thread shows the compilcations of using discrete
ICs.
2) Wouter rigging up a two PIC system in less than a day shows the power of
programming.
It's the reason we all use computers for information and communications
tasks today: programmability of fixed hardware to perform a multitude of
different tasks.
So I'd advise getting Wouter's WISP628 or my Trivial Programmer, grab a
handful of PICs (be sure to check out both Wouter's and my which pic to
choose at http://www.voti.nl/swp and http://www.finitesite.com/16F628.html
respectively) and get going.
You can program in hardware or you can program software, but in any case you
are going to be programming.
BAJ
W
Wouter van Ooijen
Not realy, I use my own compiler & libraries (Jal), which has an
off-the-shelve bit-banged UART. But I wrote this protocol some time
ago, so I had it available too.
Note that it is not self clocking in the sense that there is no clock
tolerance requirement at all: no single wire protocol can do that.
Wouter van Ooijen
http://www.voti.nl
W
Wouter van Ooijen
Roughly: a zero is 1 ms high followed by 2 ms low, a one is 2 ms high
followed by 1 ms low. Actual times are different, and there is some
added complexity to detect a byte boundary.
As an excercise for the reader: how much difference in the sendand
receive clock does this protocol allow?
Wouter van Ooijen
http://www.voti.nl
F
Frank Bemelman
16.7% ?
Just a wild guess!
F
Fred Bloggs
Wouter van Ooijen
http://www.voti.nl
Quite a bit- like 1/2 Tclk error before bad reception. Detecting bytes
and errors becomes less of problem if the byte is encoding an ASCII
character.
U
Uns Lider
What if you use a protocol similar to the encoding used for mag stripes?
-- uns
