Double pull double throw switch
douggarvin
Apr 26, 2005
4
what is the true table for a dpdt switch.  it has  on-off-on , 6 terminals
            1 o      o  4
            2 o      o  5
            3 o      o  6
Pins 2 and 5 control the switch??
GreekPIC
Aug 1, 2004
251
First of all it's Double Pole Double Throw. A Single Pole Double Throw (SPDT) would only have pins 1,2,3.
The signal you connect to pin 2 will be routed to pin 1 when you put the switch to one ON position and to pin 3 at the other ON position. When it's at the OFF position pin 2 won't be connected to anything.
All that times two for the other pins. Actually it's like having two SPDT switches side by side.
Nikolas
