DS1307 can not read and write time in arduino.
Ninjia Chen
Nov 7, 2014
10
hello everyone
In mid-November, I have designed a shield based on arduino.I have wrote two posts https://www.electronicspoint.com/th...netometer-clock-and-oled.271203/#post-1633487 and https://www.electronicspoint.com/th...tes-a-variety-of-sensors.271379/#post-1631633 I have to debug a week.However, it does not work.The OLED display and bluetooth is ok.
Here is my sch,
Here is my pcb
You can see in my schematic,I use IIC to connects two devices,they are not wroking properly.First, I tested the DS1307.I found the DS1307 has no answer.
Here is my code base on arduino.
Code:
#include <Wire.h>
int clockAddress = 0x68;  // This is the I2C address
int command = 0;  // This is the command char, in ascii form, sent from the serial port
long previousMillis = 0;  // will store last time Temp was updated
byte second, minute, hour, dayOfWeek, dayOfMonth, month, year;
byte test;
// Convert normal decimal numbers to binary coded decimal
byte decToBcd(byte val)
  return ( (val/10*16) + (val%10) );
// Convert binary coded decimal to normal decimal numbers
byte bcdToDec(byte val)
  return ( (val/16*10) + (val%16) );
// 1) Sets the date and time on the ds1307
// 2) Starts the clock
// 3) Sets hour mode to 24 hour clock
// Assumes you're passing in valid numbers,
// Probably need to put in checks for valid numbers.
void setDateDs1307()
  // Use of (byte) type casting and ascii math to achieve result.
second = (byte) ((Serial.read() - 48) * 10 + (Serial.read() - 48));
  minute = (byte) ((Serial.read() - 48) *10 +  (Serial.read() - 48));
  hour  = (byte) ((Serial.read() - 48) *10 +  (Serial.read() - 48));
  dayOfWeek = (byte) (Serial.read() - 48);
  dayOfMonth = (byte) ((Serial.read() - 48) *10 +  (Serial.read() - 48));
  month = (byte) ((Serial.read() - 48) *10 +  (Serial.read() - 48));
  year= (byte) ((Serial.read() - 48) *10 +  (Serial.read() - 48));
  /*second = 50;
  minute = 56;
  hour  = 9;
  dayOfWeek = 2;
  dayOfMonth = 2;
  month = 12;
  year= 14;*/
  Wire.beginTransmission(clockAddress);
  Wire.write(byte(0x00));
  Wire.write(decToBcd(second));  // 0 to bit 7 starts the clock
  Wire.write(decToBcd(minute));
  Wire.write(decToBcd(hour));    // If you want 12 hour am/pm you need to set
  // bit 6 (also need to change readDateDs1307)
  Wire.write(decToBcd(dayOfWeek));
  Wire.write(decToBcd(dayOfMonth));
  Wire.write(decToBcd(month));
  Wire.write(decToBcd(year));
  Wire.endTransmission();
// Gets the date and time from the ds1307 and prints result
void getDateDs1307() {
  // Reset the register pointer
  Wire.requestFrom(clockAddress, 7);
  // A few of these need masks because certain bits are control bits
  second     = bcdToDec(Wire.read() & 0x7f);
  minute     = bcdToDec(Wire.read());
  // Need to change this if 12 hour am/pm
  hour       = bcdToDec(Wire.read() & 0x3f);
  dayOfWeek  = bcdToDec(Wire.read());
  dayOfMonth = bcdToDec(Wire.read());
  month      = bcdToDec(Wire.read());
  year       = bcdToDec(Wire.read());
  Serial.print(hour, DEC);
  Serial.print(":");
  Serial.print(minute, DEC);
  Serial.print(":");
  Serial.print(second, DEC);
  Serial.print("  ");
  Serial.print(month, DEC);
  Serial.print("/");
  Serial.print(dayOfMonth, DEC);
  Serial.print("/");
  Serial.print(year, DEC);
void setup() {
  Wire.begin();
  Serial.begin(57600);
void loop() {
  if (Serial.available()) {  // Look for char in serial que and process if found
    command = Serial.read();
    if (command == 84) {      //If command = "T" Set Date
      setDateDs1307();
      getDateDs1307();
      Serial.println(" ");
    else if (command == 81) {  //If command = "Q" RTC1307 Memory Functions
      delay(100);
        // If command = "1" RTC1307 Initialize Memory - All Data will be set to 255 (0xff).
        // Therefore 255 or 0 will be an invalid value.
        if (command == 49) {
          // 255 will be the init value and 0 will be cosidered an error that
          // occurs when the RTC is in Battery mode.
          // Set the register pointer to be just past the date/time registers.
          Wire.write(byte(0x08));
          for (int i = 1; i <= 27; i++) {
            Wire.write(byte(0xff));
            delay(100);
          getDateDs1307();
          Serial.println(": RTC1307 Initialized Memory");
        else if (command == 50) {      //If command = "2" RTC1307 Memory Dump
          getDateDs1307();
          Serial.println(": RTC 1307 Dump Begin");
          Wire.requestFrom(clockAddress, 64);
          for (int i = 1; i <= 64; i++) {
            test = Wire.read();
            Serial.print(i);
            Serial.print(":");
            Serial.println(test, DEC);
          Serial.println(" RTC1307 Dump end");
    Serial.print("Command: ");
    Serial.println(command);  // Echo command CHAR in ascii that was sent
  command = 0;  // reset command
  delay(100);
Time is always parked in the 45:85:85,I know this is the wrong data.I use two leonardo to test.Unfortunately, I still did not get the correct data.Then,I suspect that the IIC on my leonardo is broken.
I've used other IIC devices, I put GY-30 connected to leonardo, and the code I‘ve been used,it can't work.I borrowed a Duemilanove from others.The GY-30 can work,and the DS1307 in my shield doesn't work.Now I have no idea.anyone can help me,and anyone can upload code about DS1307 base on arduino,In order to confirm the problem in my code or on my PCB.
Ninjia
Have you tried to communicate with the DS1307 when it alone is on the I2C bus?
Are you using code you've written yourself or a library you've obtained from elsewhere?
Have you tried setting the time then reading it back?
KrisBlueNZ
Sadly passed away in 2015
Nov 28, 2011
8,393
Can you provide a link to the data sheet for the AP2306 devices that you're using to convert the I2C signals between 3.3V and 5V? I can't find a data sheet for it anywhere.
If you can't post a link to it, upload it as an attachment to your post.
If you don't have a data sheet for it, post a link to the article that showed you how to use it to level-shift an I2C bus.
Ninjia Chen
Nov 7, 2014
10
yeah,thanks you.I find it on http://www.amobbs.com/thread-4856717-1-1.html,
You can use the Google translator to read.
Ninjia Chen
Nov 7, 2014
10
Thanks,I will test it again on Saturday as you said.
Ninjia Chen
Nov 7, 2014
10
That's the URL of the discussion thread.
Can you post the URL of the data sheet please.
Thanks,Moderator,I know what the problem.If there is no AP2306, DS1307 can work properly.
I should not be free to use the circuit which has not been proven.I did not find the relevant datasheet, only a discussion.
