ds1722 on parallel port using SPI
Lauwe
I got a ds1722(http://www.maxim-ic.com/quick_view2.cfm/qv_pk/2766) and i
want to interface it to my pc so i can read temperatures. i used the scheme
found at http://www.reed-electronics.com/ednmag/contents/images/245653f1.pdf
no matter what register-byte i write (like 80h, supposed to be write-only)
the chip seems to return the default configuration register (1110 0011)
(even when i set the configuration-register different and try to read it).
to me this indicates there is somesort of problem with the way i try to
write data since it seems to fail every time (sending 0000 0000) wich is the
address that will retrieve the configuration-register for me.
i use the following visual-basic code to retrieve MSB:
Debug.Print "reading temp"
'read first byte at 02h
'set CE high d6 high and d0 high
DlPortWritePortUshort 888, 65
Sleep 100
'first write address 02h (00000010)
'write 6 zeros
For i = 1 To 6
'raise clk leave SDI low
DlPortWritePortUshort 888, 67
Sleep 100
'lower clk (SDI remains low)
Sleep 100
Next i
'write 1 one
'raise clk and SDI high
DlPortWritePortUshort 888, 71
Sleep 100
'lower clk (and SDI)
Sleep 100
'write 1 zero
Sleep 100
Sleep 100
'now we are ready to read 1 byte
For i = 1 To 8
'raise clk
Sleep 100
'read bit
Debug.Print DlPortReadPortUchar(889)
Sleep 10
'lower clk
Sleep 100
Next i
'Transfer complete: lower CE
DlPortWritePortUshort 888, 1
Sleep 300
if someone could explain to me what i am doing wrong it would be greatlu
appreciated.
tnx,
Laurens
K
Klaus Vestergaard Kragelund
Snip...
Is the port set to the SPP (Standard Parallel Port) Mode? It seems to me you
are using direct control of the parallel port and you need to set the
correct mode in that case. And someone mentioned that windo$e 2000/XP has
problems with those direct calls.....
Cheers
Klaus
Si Ballenger
Can the SDO on the chip pull parallel port pin #12 low enough to
indicate the data? I've just made two parallel port pages below
that do similar stuff. Note on the contact/switch page I had to
use a transistor to pull the status lines low. I've been looking
at using a TI TLC542C chip to do some data reading also. I use a
program called userport to get hardware access.
http://www.geocities.com/zoomkat/status.htm
http://www.geocities.com/zoomkat/output.htm
Lauwe
Yes, the SDO can pull pin 12 low enough because i do get data from the chip.
i think the problem is caused by the way i try to write high-bits, but can
this be because of timing? (i didn't think so because i control the CLK). i
have been looking at the waveform-figures and i can't quite find out if i am
following these figures (i think i am).
i have tried to write high-bytes like i do in the vb code: put clk(parport
pin3) and SDI(parport pin4) high, and then put them bolth low again
also tried: putting clk high; then putting SDI high; then putting SDI low
and then putting clk low.
but i still feel that the problem is being caused by not being able to write
the high-bits.
so the SPP-thing didn't work..
ps. tnx for all reactions so far!
----- Original Message -----
Newsgroups: sci.electronics.design
Sent: Saturday, January 03, 2004 9:51 PM
Subject: Re: ds1722 on parallel port using SPI
Si Ballenger
Try setting the sleep to something like 6000 (6 seconds ?) and
have multimeter connected between the parallel port pin lines and
ground. When you set a line high, you should be able to see if
the pins go to +5V in that 6 second time frame. If they don't,
then you are not accessing the computer hardware with your
program. If you are using a computer that is running NT/2K/XP are
you using a dll or something similar that gives access the
parallel port hardware? VB is not natively allowed this type of
hardware access on NT/2K/XP machines.
Lauwe
I just did a test with the multimeter and it tells me that high's are 3.47V
and lows are 0V... but these can't be to low because CLK seems to be working
fine..
(and i am using dlportio, and it has worked before..)
Lauwe
tnx for all the help guys but i found out what was wrong. it seems i lowered
the SDI to soon so it didn't see the bit as a 1 but a 0 with this code it
works:
'write 1 one
'raise SDI
DlPortWritePortUshort 888, 69
Sleep 10
Debug.Print "1"
'raise clk
Sleep 10
'lower clk
Sleep 10
'lower SDI
Sleep 10
