DSC 5010 & 2 wire smoke
mattl
Hi All,
I have a DSC 5010 with a Sentrol 429CT 2 wire smoke detector.
I have the detector wired to the PGM2 and AUX+ with an eol and jumper
CON1 is removed as described in the manual (2.9.5).
My question is, how do I program that "zone" as a "Delayed 24 Hour
Fire Zone" when it in fact is not hooked up to a zone.
At present, when the smoke detector is activated the fire bell squacks
and the panel imidiatly dials the central station. I would like to
have a delay to take the pot off the stove then press a key on the
keypad to cancel the communication to the central station.
Any suggestions?
matt
alarman
mattl wrote
Hi All,
Any suggestions?
The delayed fire option is not available on the pgm 2 2-wire smoke detector
zone. If you want delayed fire, use a 4-wire smoke, and connect it to one
of the zones (1-32).
js
AlarmTechnologies
Hello Matt,
Don't believe you can do what you want without going into a 4-wire
detector.
Although you might want to try (location 370) Transmission Delay Time
to see if you can delay transmission of the signal(I'm not sure if it
will delay a 2-wire fire signal though...).
Yours in Security,
Robert G. Seketa
RGS Technologies
216-322-9111
RGS@[removethis]AlarmTech.org
www.AlarmTech.org
AlarmTech/SmartMonitoring Dealer Network
