dsc power 832 bell operation
K
Keith
I have installed a dsc power 832 system in my home as it was built.
Now I am attempting to program the system and all is well so far, but
when I connect the "bell" circuit to my indoor siren, it produces a low
volume churp which I can not figure out why or how to turn off. It
does not time out based on the bell timer and I show no alarms on the
panel. I did not install any resistors in the circuit. Any ideas??
Robert L Bass
IIRC, the panel has a supervision voltage across the bell terminals, similar
to what Napco does. With Napco panels you can sink the voltage (and kill
the low volume tone) by wiring a 2200 Ohm resistor across the outputs.
Presumably the same will work on DSC, however, it may be possible to program
the feature out. I rarely program DSC so someone else will have to tell you
for sure.
Regards,
Robert L Bass
Bass Home Electronics
4883 Fallcrest Circle
Sarasota · Florida · 34233
941-866-1100 Sales & Tech Support
http://www.bassburglaralarms.com
J Barnes
Yes, DSC requires the same 2200 ohm resistor "red-red-red" on the bell
circuit.
James
alarman
That panel supervises the bell circuit with a very low voltage. Place a 1K
ohm resistor across the siren terminals.
js
F
Frank Olson
The proper way to eliminate the "chirp" is to place a 1K ohm resistor
across the bell/siren terminals *at the siren* so supervision by the
panel is maintained.
The best way to eliminate the "chirp" is to purchase a DSC siren.
Contact a local alarm company that deals with DSC and buy one from them.
Cost will be around $20.00 (or less). You won't need a resistor.
K
Keith
I installed a 1K resistor and the noise reduced but did not go away. I
ended up using a 500 ohm resistor which seemed to work. I am assuming
the siren I have is different than the dsc models.
