EDA tools, like schematics/PCB CAD /circuit simulator for OS/2?
Chaos Master
Hi.
Are there any EDA tools (schematics drawing program, PCB drawing,
circuit simulator) program that works on OS/2?
[]s
Chaos Master®, posting from Canoas, Brazil - 29.55° S / 51.11° W
"People told me I can't dress like a fairy.
I say, I'm in a rock band and I can do what the hell I want!"
-- Amy Lee
Running on: 300MHz Pentium, 128MB RAM, 8.4GB HD, 56k modem, Windows 98
SE
Mozilla Firefox 1.0, Gravity 2.70, Wget as downloader
Mat Nieuwenhoven
On Mon, 10 Jan 2005 03:08:05 -0200, Chaos Master wrote:
:>Hi.
:>Are there any EDA tools (schematics drawing program, PCB drawing,
:>circuit simulator) program that works on OS/2?
About two years ago I tried Eagle (www.cadsoft.de). It has schematic/pcb
only, no simulation; maybe someone has interfaced it to Linear Technology's
simulator, you can ask at the newsgroups at news.cadsoft.de . It has a Win32
and Linux version, and the then-Odin wasn't up to the task (black icons and
other problems), plus I recall having to use a Win98 machine to do the
install. I still use Eagle, but boot to Linux on the same box to use it. If
you try it and get it to work, I'd appreciate it if you let it be known here.
Mat Nieuwenhoven
Paul Floyd
Hi.
There are some oldish versions of SPICE.
A bientot
Paul
Mat Nieuwenhoven
On Mon, 10 Jan 2005 06:28:53 +0100 (CET), Mat Nieuwenhoven wrote:
:>On Mon, 10 Jan 2005 03:08:05 -0200, Chaos Master wrote:
:>:>Hi.
:>:>Are there any EDA tools (schematics drawing program, PCB drawing,
:>:>circuit simulator) program that works on OS/2?
:>About two years ago I tried Eagle (www.cadsoft.de). It has schematic/pcb
:>only, no simulation; maybe someone has interfaced it to Linear Technology's
:>simulator, you can ask at the newsgroups at news.cadsoft.de . It has a Win32
:>and Linux version, and the then-Odin wasn't up to the task (black icons and
:>other problems), plus I recall having to use a Win98 machine to do the
:>install. I still use Eagle, but boot to Linux on the same box to use it. If
:>you try it and get it to work, I'd appreciate it if you let it be known here.
I've now learned via c.o.o.a that Eagle works under OS/2. I've downloaded the
Win32 version 4.13r1, installed it using unzip and Stix, running under
Netlabs' latest Odin xp release from 20041231. Icon are still almost black,
mousewheel doesn't zoom (have to use F3/F4), and printing has to be done via
the CAM processor creating Postscript output (then use Ghostscript to print),
but it works!
Mat Nieuwenhoven
F
Franz Bakan
downloaded the Win32 version 4.13r1, installed it using unzip
and Stix, running under Netlabs' latest Odin xp release
try to modify ODIN\system32\ODIN.INI
[WinVersion]
Version=Win2000
Franz
Mat Nieuwenhoven
On 11 Jan 2005 13:38:20 GMT, Franz Bakan wrote:
:>On 2005-01-11, Mat Nieuwenhoven wrote:
:>> I've now learned via c.o.o.a that Eagle works under OS/2. I've
:>> downloaded the Win32 version 4.13r1, installed it using unzip
:>> and Stix, running under Netlabs' latest Odin xp release
:>> from 20041231. Icon are still almost black,
:>try to modify ODIN\system32\ODIN.INI
:>[WinVersion]
:>Version=Win2000
Thanks, but it didn't help. Twiddling with os2look, UseWinColors and
WinVersion in many combinations made very little difference: all buttons in
e.g. the schematic editor have a black background.
Mat Nieuwenhoven
Mat Nieuwenhoven
:>Hi.
I've just tried Linear Technology's SWCadIII simulation /schematic entry
program using Odin xp release 2004-12-31 from Netlabs. It installs perfectly,
looks perfect. I tried some schematic entry which seems to work, haven't
tried simulation. It has no PCB layout capability. Print setup shows the
proper printer but freezes the application, and help doesn't work (apparently
Odin doesn't contain a Windows help format viewer).
Mat Nieuwenhoven
