Electric Toothbrush
LoriCraig
Mar 11, 2017
Hi!
My Electric Toothbrush suddenly stopped working. No matter how I fully charge it.
Can I easily fix this?
If it's sealed, even if you can fix it, you may have a hard time sealing it again.
If the problem is water leaking into it, the damage may be hard to repair (if you shake it can you hear liquid inside?)
If it's just a failed battery you might be able to replace it.
It's also possible that the charger or the charging circuit has failed.
SalRu
Mar 16, 2017
12
Hello.
I agree with steve.
Maybe you can manage to repair it by opening it and make some changes depending on what's wrong.
The real problem will be when you will close it. If it's not well sealed and water enters it, this will create big problems.
Be careful and good luck!
Herschel Peeler
Feb 21, 2016
401
Hi!
Not necessarily an electrical problem. Maybe a buildup of toothpaste in the mechanism. Take it apart and clean it.
Maybe a bad switch.
