electronic fuel injection
dheepak
i am currently doing a project on multiple fuel injection in auto
engines.i would like to get some information on my subject including
basic ideas and practical requirements.i also want to know how to
achieve maximum efficiency using electronic fuel injection.any kind of
help is appreciated...thanks
Rich Grise
This is terribly vague. What don't you know? Do you know how to design,
build, and program a microprocessor circuit? Do you know if the injectors
will be solenoid-driven, or some other technique? Do you know about PWM?
Do you know about power MOSFETs? Do you know about the automotive electrical
environment?
Ths simplest answer is, interrupt your microprocessor at some repeatable
time during the timing cycle, and adjust pulse width, duty cycle, and
delay until you get the best efficiency.
Good Luck!
Rich
Anthony Fremont
environment?
Check this out, I've watched this project for about a year or so though
not too much lately as the car I was going to "squirt" had a
transmission failure so that project is now on hold. The megasquirt is
getting to be pretty good at it's capabilities.
http://www.bgsoflex.com/megasquirt.html
Robert Baer
Too bad that it is unreliable from 165C and higher...
Anthony Fremont
Robert Baer said:
That's why you put it inside the passenger compartment, just like the
auto manufacturers. I really don't see that as a problem for a DIY
project.
~^Johnny^~
environment?
In all but the most rudimentary systems, software-based 3-dimensional mapping
is involved, and few hackers will get that far...
-john
wide-open at throttle dot info
Always listen to experts. They will explain what
can't be done and why. Then do it. - Robert Heinlein
