Electronic Transistor Ignition
  • Thread starter Jack Jet Williams
  • Start date
Jack Jet Williams
Would someone please show me a simple diagram of how to use a
transistor to fire the ignition coils on a 750 Honda motorcycle - I
just want to have the breaker points switch the transistor to fire the
coils so the points do not burn/wear out so fast.
Thanks.
Jack Jet Williams
Hesperia,Ca.
default
Thanks.
Jack Jet Williams
Hesperia,Ca.
Try this link: www.cs.berkeley.edu/~wkahan/TransIgn.pdf
default
THANKS !
This is JUST what I needed to see.
Thanks again>>>>>>>>>!!!
Jack Jet Williams
Hesperia,Ca.
I figured it would be perfect.
You want to make sure you use a choke with at least the 10-15 ohms of
resistance specified (one with a lower resistance may effect how the
transistor turns on).
That is a germanium transistor specified. They can still be found.
Use a silicon part and you may need to tweak the design some.
What year 750? I'm riding an '81.
