Embedded microcomputer software structure
Baxter Burgundy
Nov 18, 2014
38
Again not homework, but help with revision. I've got the following question I'm not really sure on, kind of similar to the other I posted last night:
(c) An embedded microcomputer based instrument is to be designed around the following three principal tasks:
  • A user interface using a keyboard & LCD
  • Multi-drop serial communications that principally retrieves data from the instrument
  • Periodic recording of 2 analogue values every 10ms
Design a suitable software structure for the above application giving details of any interrupts necessary to generate reliable communications & data without inducing noticeable time delays when using the instrument.
Cheers
Arouse1973
Adam
Dec 18, 2013
5,178
Sounds like a job for RS485. They don't give you much info do they? So is the data and the analogue values the same thing or separate?
Adam
Baxter Burgundy
Nov 18, 2014
38
The focus of the module has been on the PIC 16F877 so I think they'll be wanting the answer centered around that. The way it reads I would assume the data and the analogue values to be the same thing.
