EMC compliance testing
Scott Miller
I'm working on a product that will apparently need FCC Class B certification
in the US, and the equivalent CE Marking in Europe. Can anyone suggest a
good, low-cost lab for the testing? Like under $2500?
Does anyone do cheaper 'pre-testing' so that I might gauge how close I am to
compliance? I really don't have the equipment I need in-house to do that
sort of testing.
Scott
Pooh Bear
Not in the US. Don't forget that you also need to meet the Low Voltage Directive
( safety ) too to apply the CE mark.
sort of testing.
Pre-compliance testing is a good idea, especially if you're new to it all. I
chanced up on a semi-retired emc expert who we use from time to time. Last time,
I think he charged about £300/day and brought the necessary equipment to us.
You'll need to find a suitable location for certain tests too that's 'rf benign'
e.g. has no steel in the construction of the building and isn't near anything
like that. We used a hut in a playing field.
Graham
Leon Heller
http://www.geocities.com/leon_heller
certification in the US, and the equivalent CE Marking in Europe. Can
anyone suggest a good, low-cost lab for the testing? Like under $2500?
to compliance? I really don't have the equipment I need in-house to do
that sort of testing.
Where I used to work they book a test facility for half a day for
preliminary testing. It isn't expensive. That usually shows up one or two
problems with emissions which are easily fixed and the equipment generally
passes fist time after that.
Leon
Scott Miller
Directive
The device will be powered by USB or a 9-volt wall wart. It's my
understanding that it doesn't need Low Voltage Directive compliance if it's
under 75 VDC and the external power supply is itself approved. Is that
right?
I
time,
us.
benign'
anything
Anyone know where I can find someone like this in California? I'm new to
this and it'd be nice to have some hand-holding. And if it's someone
willing to give a break to a very small startup company, that'd be even
better.
Scott
Scott Miller
And would the company provide their own engineers for the testing, or does
that come with the facility? I'd like to talk to someone who's been through
the whole testing cycle - there's a lot I don't understand about the test
setup, especially when it comes to adding cables and connecting the device
under test to other devices.
Scott
R.Lewis
right?
Everything needs consideration to the LVD.
Just because the supply to your equipment is SELV (not 75V by the way) it
does not mean that your equipment is 'safe'.
A simple example is the camping fluo lamp. This works off a 12V car battery
but powers a fluorescent tube that is often cold cathode struck and requires
an output of several hundred volts.
However if you are confident (and expert) enough to verify that the
equipment will not 'step up' the incoming SELV , or the user will have no
access to a voltage above SELV, then just declare it as such.
Rene Tschaggelar
After telling us the corner specifications, we could
introduce you to the required tests.
Is the device for industrial / household / medical applications ?
Is it powered from the powerline / batteries / external power supply ?
Is it connected to other stuff ? By what connection ? Serial ?
What is the highest internal voltage ? < 48V ? > 48V ? line ?
Rene
Pooh Bear
right?
Ahhh - OK - then no need for LVD.
better.
If you're new to it, the hand holding is invaluable. I've used that consultant I
mentioned since ooohhh 1987 and I've leant many of the tricks of the trade from
him.
Good luck looking. I just asked around and got lucky.
Graham
Scott Miller
Household. There would certainly be some commercial/industrial usage, but
more often hobbyists in a home environment.
Power will be supplied through USB connection (5 volts) or external supply
for standalone operation - generally an off-the-shelf 9v wall wart I expect.
Maximum input voltage would be maybe 14 volts. The majority of the
internals will run at 3 volts. Haven't chosen a regulator yet, but it won't
be anything elaborate. No plans for internal batteries at this point.
It could connect to a PC through USB or RS-232, GPS receiver through RS-232,
and VHF or UHF radios through an audio cable. It's got an SD/MMC flash card
slot for removable storage.
Scott
Rene Tschaggelar
By only using low voltage to be supplied from external,
you already offloaded the power line spike tests.
Next then is radiated and conducted emission as well as
radiated and conducted susceptibility to RF from DC to
3GHz. There, your working device with its standard
connectionsis subject to
1) radiation in the mentioned frequency range on cable
or through the antenna. The device has to keep on
working.
2) the radiation of your device on cable as well as on
cable is measured and some values not to be exceeded.
Power and signal lines can be made to conform by shorting
the RF to the case with 100nF caps for DC and smaller ones
depending on the signal frequency. Oops, household cases
are usually not from metal.
Industrial metal cases have to be earthed.
Household cases are usually from plastic, this is somewhat
harder to shield.
Rene
Jeff
I recently used UL for just the FCC Class B and paid about that amount,
which was the lowest fee I have ever paid for this testing. I think UL just
added this service recently. Up to now we used independent labs.
Jeff
Scott Miller
This will be a metal case - either steel or aluminum, still working with the
enclosure vendor on that. It'll add a few dollars to the price compared to
a plastic case, but I think it'll be worth it. Aside from the shielding,
there's marketing value in providing a sturdy, durable enclosure. Too many
products these days are cheap and fragile.
I saw some mention of having a ground (earth) connection to the case through
a screw that serves no other purpose - i.e., not a screw that holds the case
on. I don't remember who's requirement that was - might have been a UL
thing, and I'm not sure if it's applicable.
I will certainly have plenty of decoupling on the power and signal lines. I
hadn't given any thought yet to the electrical connection with the case. I
suppose it'll just have the ground plane exposed around the screw holes.
I'll ask my PCB and enclosure vendors how they usually set that up.
Thanks...
Scott
Scott Miller
Someone was just telling me that UL was outrageously expensive, but maybe
that was for their usual safety testing. I suppose they try to sell you
their other services as well?
Scott
Pooh Bear
Undoubtedly !
The last lab I used for conformity testing was ETL Semko in the UK. They weren't
too bad on price but hopeless as regards understanding the cable connections for
a practical test. That's especially difficult with a product like an audio mixer
as I was submitting, where you can have so many possibilities - you just have to
make a sensible compromise between minimal and absurdly out of the world
possibilities.
I notice they are represented in the USA too.
http://www.usa.intertek-etlsemko.com/
Worth a call I reckon. Explain that you need FCC and CE at the same time and
there should be minimal extra cost. They just need to run some tests with
slightly different limits. CE requires immunity though - which I believe FCC
still doesn't ( not sure it can require so, given it's role in the regulatory
structure - but pls correct me if I'm mistaken ).
Graham
Scott Miller
I'll check them out.
FCC
regulatory
I think you're right. Part 15 doesn't specify any immunity requirements,
though it does say something about the device having to accept any
interference caused by other devices.
Scott
