Emitter follower differ GND potential
Jerry Norris
I have generated a 20Hz sinewave at 5Vpp. The circuit runs on 6V
battery power with a normal earth reference at 0V.
To obtain higher current, I would like to feed this into a darlington
emitter follower that has +12V and +6V rails. Yes, I do need it that
way.
In terms of circuitry, how do I deal with the lack of a common
"ground" potential?
Jerry Norris
Jerry Norris
Are you concerned with lack of Earth ground or are you concerned because you
have 0V, 6V, and 12V? Need more info.
The end result is intended to be a symmetrical output swing between
the +12 and +6 volt rails of the darlington.
What I need to know is how to input to it a 5V signal with its 0V
ground reference.
IOW the input 0V needs to be shifted up to +6V to match the higher
"ground" potential in the darlington.
Jerry Norris
