Guy Macon
- Jan 1, 1970
- 0
Disclaimer: I designed an EMP simulator for the military, but this
post is derived from publicly available information and does not
contain any details of that design. I can say that this document:
http://www.interferencetechnology.com/ArchivedArticles/lightning_and_transients/I96art07.htm
pretty much matches what I know on the topic.
This is a very good question.
The first step in answering it is to realize that the earth has already
experienced many Nuclear EMPs, one of the largest being Starfish Prime
in 1962; 1400 kilotons 400 km over Johnston Atoll, causing an artificial
aurora borealis and effects in Hawaii. There were a lot of mechanical
wristwatches and other precision mechanisms on the ship right below
that EMP, and there were been no reports of failures. As an aside,
many reports simply say "power outages in Hawaii." The actual effect
was the simultaneous failure of 30 strings of series-connected
streetlights in Oahu -- about 1% of Oahu's streetlights -- becauuse
of blown fuses.
Also in 1962, The USSR set off a 300 kiloton warhead 290 km over Dzhezkazgan.
The EMP fused 570 km of overhead telephone line with a measured current of
2,500 Amperes, started a fire at a Karaganda power plant, and shut down
1,000-km of shallow-buried power cables. This is worse than the hawaii case
because the lines were far longer, being on a continent and not an island.
It didn't, however, destroy any mechanical wristwatches.
The next step in answering this is to consider this quote:
"this pulse is very roughly comparable to the electromagnetic
fields radiated from a nearby lightning stroke"
http://www.interferencetechnology.com/ArchivedArticles/lightning_and_transients/I96art07.htm?regid=
Many people and lots of equipment have had near-misses from
lightning strokes, and there have been no reports of mechanical
damage to watches.
Next, consider the logic of assuming that 50 volts on a watch part
will cause damage but 50,000 volts of the person wearing it won't.
(I have seen no claims that an EMP will electrocute everyone in
it's range...) The reason for this is that a high voltage over
a short duration has limited energy. This is true of EMP and of
you touching a doorknob and getting a 50,000 volt shock.
Also consider this from
[ http://arxiv.org/ftp/physics/papers/0307/0307067.pdf ]
"At least two kinds of EMP have been identified and studied extensively...
One is an extremely fast pulse with a duration ~ 10-6 sec occurring at the
beginning of a burst, which we call TEMP (tachy[fast]EMP). Since the TEMP
was thought to have an electric field peak ~ 50 kV/m, ~ 10 to the 6 times
greater than the much slower magnetohydrodynamic EMP (MHD EMP), it was
expected that the TEMP would have a much bigger impact; and almost all the
attention was focussed on TEMP. TEMP was anticipated to have devastating
effects in electrically blacking out huge land masses; and much media
coverage was given to this possibility. However, Rabinowitz showed that
the impact of TEMP would be local rather than continental, and not be
much greater than that of lightning. Later independent work by Millard,
Meliopoulos, and Cokkinides reached similar conclusions. Consideration
of the radiation reaction force and subtle relativistic effects indicate
that 50 kV/m may not even be achievable for the preponderance of nuclear
weapons that exist."
So my conclusion is that EMP will not damage a mechanical watch movement
if the wearer is far enough away to survive the nuclear blast.
Getting back again to my original inquiry, a mechanical watch has
some very thin and delicate parts in it, such as the hairspring.
Let's assume a very thin wire 1mm in length, and the EMP pulse is
directed so that the full voltage is directed lengthways along the
wire.
In the Wikipedia data I posted a link to in my prior message (the
data came from a Government study), I saw EMP of 50,000 V/m as being
possible on the ground from an exo-atmospheric detonation of a nuclear
warhead above the U.S. So for a 1mm long, very thin wire, we might see
as much as 50 volts applied across the wire for a brief moment. Could
this be enough to frapp that part?
of blown fuses.
damage to watches.
