EPROM eraser- light on indicator?
I
Impmon
Is there a safe way to tell if the EPROM bulb (emits UV-C ray) is on?
Since it's not safe to look at the bulb, I need to know if the bulb is
on or if it's burned out while erasing EPROMs. So is there a simple
UV-C detector circuit or something? Never seen a commercial EPROM
eraser as I built mine out of 12" fluorescent lamp, long cardboard box
(sealed when in use), and a 12" germicide bulb.
I wanted to know if it's on and working beside waiting 15 min or so
and finding out none of the EPROM are erased.
jasen
"day-glo" flourescent paint, highlighter, (etc) glows brightly under UV.
I have some yellow cable-ties that were manufactured with flourescent die
in them, they glow brightly under even a blue LED.
if the box is sealed there'll be no light inside it with the bulb off,
use any sort of light detector.
Mike Harrison
Just use a perspex/plexi/polycarb/glass rod through a small hole in the case. The material will
block the shortwave UV.
Baron
Most clear LED will show some output from UV. Or file the top off a
TO18 transistor !
Similar threads
F
Replies
3
3K
Franc Zabkar
F
Replies
5
1K
Franc Zabkar
F
Replies
1K
David L. Jones
Replies
23
12K
Jason D.
