[ExpressPCB] how to print for 2 layer board ?
robb
hello,
i am using ExpressPCB and i have two layer board.
I need to print one of the images (bottom or top ) flipped and
having trouble.
there is a flip option for components so i tried to make my
drawing a component but i can not create a component with traces.
So what is the method for producing a flipped/mirrored image of
the PCB traces ?
I can export to a bmp but
thanks for any help,
robb
F
Fred M
hello,
having trouble.
the PCB traces ?
robb
Get some inkjet transparency sheets from the office supply store.
(These are made to be used with a classroom transparency projector.)
Print the layer, then flip it over.
Fred
Robert Baer
robb said:
hello,
having trouble.
the PCB traces ?
robb
You print it regular,convert to BMP or GIF and use an imaging program
for flippie floppie no flappie.
Ecnerwal
You might also look deep in the printer options to see if the printer
driver supports mirror-flipping the page (most laser drivers do,
somewhere deep in the options), without the program knowing about it.
JosephKK
robb [email protected] posted to sci.electronics.design:
hello,
having trouble.
the PCB traces ?
robb
I don't suppose that you tried creating a "flipped" version of the
component to work with.
robb
hi Joseph,
thanks for the reply, thats exactly what i ended up doing.
fortunately it was a small PCB and not too time consuming but if
i had known the software would not let me flip in the begining
then i would have started with the flipped drawing :}
i was hoping i was just missing sometjing or an iudea someone
allready found on how to do this,
thanks again,
rob
