Extending Xmas mini-light string
GJWK
Hello all, I have what I believe should be a simple question. Unfortunately
it's been about ten years since my one DC circuits class and I can't seem to
find the chart I vaguely remember needing. Basically I would like to take a
single string of Xmas mini-lights and extend them to about twelve hundred
feet or one light every eight feet along a fence line. The questing is can I
do this and if so what gauge wire would I need to stretch one string to a
twelve hundred feet? If I have the current flowing through two thousand plus
feet of wire will it fry the bulbs in series or make the bulbs on the end
too dim? I think the bulbs are about .5 watts each and I'm hoping for a
hundred fifty or so in line.
Thanks for any help
Geoff
John Woodgate
Basically I would like to take a single string of Xmas mini-lights and
extend them to about twelve hundred feet or one light every eight feet
along a fence line. The questing is can I do this
Yes, but it's not very safe. Over 1200 ft, the wire could easily be
damaged and not noticed, and someone could get a bad electric shock.
wire would I need to stretch one string to a twelve hundred feet?
See below.
If I
have the current flowing through two thousand plus feet of wire will it
No. More wire resistance reduces the voltage and current.
or make the bulbs on the end too dim?
No. In a series circuit, the current is the same everywhere. All the
lamps might be dim, but none will be if your wire resistance is low
enough.
I think
the bulbs are about .5 watts each and I'm hoping for a hundred fifty or
so in line.
Running off 120 V? I doubt you have lamps rated 0.8 V 0.5 W. We can't
advise you further because of lack of key data, and we need to know
either the rated voltage of one lamp or how many there are in a 120 V
string.
Rheilly Phoull
Thanks for any help
Geoff
It would need more information to answer that. The main item being the
supply voltage. IMHO it would not be wise to use mains in that situation but
of course with an extra low DC supply the current would occasion the need
for heavy (read expensive) cable.
If the lamps are 0.5watt x 150 gives 75watts, by putting your supply voltage
into the formula "Watts/Supply volts" you will get the current required
(With the lamps in series this will need a high voltage, see comment 1).
If you put the lamps in parallel, (which would not be your average "Xmas
string" for the tree) using the same formula you will see that the supply at
24v will need cable that will support about 3.2 amps. If you can source
cable of about 18 guage for that length it would probably suffice, since the
dimming effect would be gradual along the length IMHO it wouldnt be all that
noticeable. Personally I would connect such a string as a 'ring' if at all
possible and that would reduce any dimming to minimum.
One can not simply 'extend' mini lights in series since the number of the
lamps determines the voltage that is applied to them.
Remember when posting to always add the voltage, lamp power and supply volts
to get a better answer !
Guy Macon
You seem to think that a "single string of Xmas mini-lights" has
150 bulbs in it ("twelve hundred feet or one light every eight
feet along a fence line") instead of the usual 48.
Here is a refresher on how the lights work:
http://home.howstuffworks.com/christmas-lights2.htm
http://www.scienceplace.org/science/lights.shtml
Here is the wire data you need to know:
http://www.bnoack.com/data/wire-resistance.html
I could walk you through the math, but there is a simpler way
given your skill level.
Here is how you do it:
Keep the wiring exactly the same, but replace each short length of
wire between bulbs with an eight foot length of 12AWG stranded lamp
That's it. It will work fine.
Mac
Safety is another issue, though. Some person could be shocked by the
mains AC voltage anywhere along the line. Especially if the OP adds his
or her own bogus splices at every bulb.
To do this safely, one would need to use properly rated wire with some
kind of outdoor rated lights and junctions and so on.
Maybe it would be better for the OP to just use short strings of
LED's, with alkaline battery packs powering them. Maybe 10 LED's per
battery pack of 4 D batteries.
At least there will be no fire or risk of shock.
--Mac
GJWK
Thank you all for your help. I'm sorry for the delay in my response I was at
a birthday party and didn't get back till late. So what I have is this. I
am aware that a 150 light strand is in fact 3 strands but did not realize
why until I followed Guy Macon's links. So I think what Rheilly, Guy and
Mac's advice boils down to is that if I am very careful to splice safely I
can do it but I will need to create 3 sets of fifty lights. And if I'm right
each set will draw about 50 watts at 120v .42 amps? The first set can use 18
AWG wire. The second set 16 and the third will need 14. (See below)
0 400ft 800ft
1200
14 AWG __________________________________________
18 AWG__x__x....x__x__| |
16 AWG ________________x__x....x__x__| |
14 AWG ______________________________x__x....x__x__|
If the above diagram shows up correctly I think it shows my intentions.
Leaving the following parts list:
2400ft 14 AWG
800ft 16 AWG
400ft 18 AWG
100 each 14, 16 and 18 AWG splices (I can't remember what they're called).
1 150 light mini-light set.
Many hours of cutting, striping and splicing
Leaving two final questions can I use the original fused plug from the
mini-light set or do I need to pick something up at Radio Shack? And can I
get away with lesser gage (cheaper) wire.
I just called a supply store and priced all this wire a about $200. This is
not totally unacceptable but does mean that it will have to be something I
prepare for next year. Any suggestions, cautions or better ways to place 150
some lights on 150 some fence post will be eagerly read.
Thanks again
Geoff
Guy Macon
GJWK said:
The first set can use 18 AWG wire. The second set 16 and the third
Check the prices for overdesigning it by using 16/14/12AWG instead
of 18/16/14AWG. Also check the prices for using nothing but 12AWG.
That seems high. Did you specify lamp cord with your length
divided by two (because each length has two wires)?
You can do it with wire nuts or crimped barrel connectors.
A thermal stripper is a great tool for this sort of project.
mini-light set
Should be fine.
And can I get away with lesser gage (cheaper) wire.
How much loss of brightness and golden rather than white color
are you willing to tolerate?
Use blobs of RTV to keep the weather out of your connectors.
Consider whether LEDs will do the job.
Consider using much smaller wire and reducing the number of
lamps per series circuit so that the lamp voltage is the same.
GJWK
I had a "Well D'oh!" moment. I don't intend to sequence the lights so I'll
just string the lights with 18 AWG and have 3 strings in parallel fed by 14
AWG. I might drop the strings to 40 bulbs to make them brighter.
0 400ft 800ft 1200ft
14 ________________________________________
18 x__x__x__x_| x__x__x__x__| x__x__x__x__|
14 _|____________|______________|
I'm not sure about LED's. This setup would require 15 4packs of D
cells(10LED's each). How long would they last? It could get very
inconvenient and rather expensive.
legg
Minilights are a poor choice if you want reliability. The brighter you
run them the more likely a series section will fail completely. I've
rewired and re-lamped strings for 60% stress - resulting in yellowish
(read 'golden') light, but they run longer, if not mechanically banged
around. These are used all year round.
The expense of these things is in your labour and in your liability.
The lamp bases are constructed with crimped soffit terminals that are
reasonably safe. You are still warned to remove power before replacing
lamps. I expect few people do. 1500 feet of wiring is about 50x the
liability, regardless of the number of lamps involved.
Rope lights that use similar hardwired incandescent series strings are
also available off the shelf. These are imbedded in flexible
transparent vinyl that provides some mechanical protection, though
the vinyl degrades visibly with time. Wiring your strings in sections
of clear tubing might produce similar mechanical and electrical
protection, providing they were sealed against moisture.
Series 120vac LED strings are now marketed commercially. These have
non-replacable, molded-base bulbs and plastic envelopes (which could
theoretically be cut away). They are not prone to mechanical damage.
Obviously a different effect when illuminated - depending on the
envelope for dispersion effects - but demonstrating that there is a
more reliable solution on the horizon.
RL
Spehro Pefhany
My office "tree" (more like a collection of long twigs in a nice pot)
has mini-lights on it. I replaced one of them with a 1N4007, so the
bulbs last a few years 24/7.
Best regards,
Spehro Pefhany
Paul Hovnanian P.E.
Instead of the good kind? ;-)
Its a simple matter of measuring the length of an existing light loop
and determining its total resistance based on original length * ohms/ft
AC reactance for the original wire size. Then, select a wire size that
gives the same overall reactance for 1200 feet. Be sire to add in a few
milliohms for each splice you will be making. Cut the lamps out of the
existing loop and splice them into the new wire. Make sure your home
owners liability insurance is paid in full and plug it in.
legg
As long as they don't get banged around, which seasonal decorations
tend to, there's only environmental and operating stress to deal with.
Protected from the weather and running at half power, I imagine your
office tree will survive quite nicely, until it gets knocked over.
Enjoy.
RL
GJWK
I think I'll see what a 120 v LED string looks like. The string I'm putting
up is alongside a long driveway and is not likely to be a danger to anybody
unless the deer decide to nibble of it.
Thanks again
Geoff
