Fairchild Diodes SS14 bad factory policy ; beware !
Sagaert Johan
Hi
I wonder how in heaven its possible to get explain this.
I got a batch of PCB's witch an SS14 diode on it. made in China.
After testing ,it turned out that roughly 40% of the diodes have the
component stamping 180 degrees flipped.!
What should be the cathode is the anode !
Someone seems to re-sale trash...
I think companies like Fairchild have a an ISO 14xxx or other quality
certificate, but this issue shows that there are
serious holes in it....
Of corse this only seems to happen in China.....
I have personal knowledge where critical component measurments are disabled
to improve yield ...
(Fameous .company with roots in holland and producing film capacitors in
China )
js
Sagaert Johan
Second possible is that the SS14 are Counterfeit parts .....
W
Watson A.Name - \Watt Sun, the Dark Remover\
Could it be possible that the parts are made and labeled by a
subcontractor, and they had someone get hold of the rejects and resold
them?
Roger Gt
X-No-Archive: yes
"Watson A.Name - wrote
: "Sagaert Johan" wrote
: > Second possible is that the SS14 are Counterfeit parts .....
: Could it be possible that the parts are made and labeled by a
: subcontractor, and they had someone get hold of the rejects and
resold
: them?
: > "Sagaert Johan" wrote
: > > Hi
: > > I wonder how in heaven its possible to get explain this.
: > > I got a batch of PCB's witch an SS14 diode on it. made in
China.
: > > After testing ,it turned out that roughly 40% of the diodes
have the
: > > component stamping 180 degrees flipped.!
: > > What should be the cathode is the anode !
: > > Someone seems to re-sale trash...
: > > I think companies like Fairchild have a an ISO 14xxx or
other
: > > quality certificate, but this issue shows that there are
: > > serious holes in it....
: > > Of corse this only seems to happen in China.....
: > > I have personal knowledge where critical component
measurments are
: > > disabled to improve yield ...
: > > (Fameous .company with roots in holland and producing film
: capacitors in
: > > China )
: > > js
First: Did you get certs from the factory?
Also: did you speak with the product engineer?
And: Did you notify the distributor?
What have they said about it?
An unsupportable allegation may be your idea of a warning, but I
can't believe you have proven anything yet!
I have never had a bad lot of parts from Fairchild, but I did get
a few bad ones which they cheerfully replaced.
Roger Gt
