Ferrite/Choke question
Andrew Rossmann
I have a weird question. I recently bought a second Linksys BEFSX41
VPN router to test out some new firmware before deploying it elsewhere.
I noticed that when it was on, there was a very audible buzzy/hissing-
like noise coming from it. I ended up opening it up and tracing it to
two chokes on the 12VDC input line. They look like Fig D in the
following link:
http://www.jwmiller.com/pdf2/FB2000.pdf
By moving them around, I could sort-of make the noise worse or better,
but couldn't eliminate it. As a temporary workaround, I simply shorted
them out with a solder bridge on the solder-side of the board.
On the other router, you can barely hear the hissing only when your
ear is pretty much presed up against it.
My question is: What is causing the hissing, and why is it doing it on
DC? Any fixes to stop the hissing without losing the EMI suppression?
TimPerry
following link:
these days manufacturers do not include parts that are not needed.
glue the ferrite in place. a little glob of RTV silicon caulk should work.
I
I.F.
following link:
If there is a no_junk in my address, please REMOVE it before replying!
All junk mail senders will be prosecuted to the fullest extent of the
law!!
http://home.att.net/~andyross
My guess would be that these chokes filter ripple current from a high
frequency switch mode PSU, the best way to stop them ringing is with fast
setting araldite epoxy - allow it to run into the holes through the ferrite
where the wires run through.
Andrew Rossmann
The power supply is your basic plug-in brick. I tried both the
original and a RadioShack that is heavy enough to NOT be any form of
switching supply. Both are standard 120V in, 12VDC/1A out.
I
I.F.
law!!
I have several old modems laying about that use 230V to 12V wall-wart
adaptors and SMPSU circuits on the modem board to provide the variety of
voltage rails required by the modem - if an old modem has this level of
technology, don't you think it could be found on a modern router?
Jeff Liebermann
The wall wart just supplies unregulated DC power to BEFSX41. The
switching supply inside the BEFSX41 takes the 12VDC down to 3.3VDC to
run the router. I couldn't find the FCC ID to display the inside
photos from the FCC web pile. The various WRT54G wireless routers are
similar inside. Note the photos at:
http://www.linksysinfo.org/modules.php?name=Content&pa=showpage&pid=6
In the upper left corner of the board, you'll see the same ferrite
beads. The switching regulator is nearby. The ferrite beads keep the
RFI from leaking out of the box via the 12VDC power cable.
Incidentally, I use hot melt glue instead of epoxy for vibration and
noise reduction. It makes less of a mess. If desperate, I use RTV
(silicon rubber goo).
