Ferrofluid as Core Material
Louis Porter
Can anyone predict how ferrofluid would function as an electromagnetic
core material for RF? The point would be that, unlike solid ferrite,
it would closely immerse the entire coil. Not sure about its
properties in this regard though, and the stuff is a bit expensive for
an uneducated guess.
Louis Porter
Tim Williams
They should make ferromayo, that stuff lasts forever :)
Tim
Les Cargill
I got a sample of ferrofluid years ago in a sealed glass tube and the
material in solution congealed. I'm not sure it is very stable.
I would think it's an emulsion or suspension more
than a solution. <Googles....> they are colloids,
and colloids are not stable for long.
tm
Tim
Isn't that what jap screws are made of?
Les Cargill
Tim
I expect ferropeanutbutter *would* last forever!
Dirk Bruere at NeoPax
The wiki goes into stability of the fluid. I hadn't realized they use
the fluid in disk drives.I know it is used in high fidelity speakers.
You could always make up your own eg grind up ferrite and mix it into
molten wax or somesuch before casting it.
K
Kevin McMurtrie
Louis Porter
Aren't some inductors already using ferrous epoxy? I seem to recall
cracking open some surface mount chokes and seeing no gaps around the
wires.
Ferrofluid would be erratic because the particles can move around by
gravity and low frequency fields, at a speed that would be temperature
dependent.
Clifford Heath
I believe the Internet wisdom for making your own ferrofluid is
to precipitate iron oxide from FeCl3 solution, in stearic acid.
You get nice small particles that way...
But do you want small particles?
