Flat screen TV inductor question.
amdx
I parted out a flat screen TV, I pulled an inductor off a board. The
inductor is about 3" long and an inch in diameter. It is wound with a
litz type wire and the value is 5.6uH.
I'm curious, what was the use of this coil. It seemed to carry a
pretty heavy current, because it was mounted with 4 pins on each end and
all four pins were connected to the litz. Also the solder joints to all
the pins were over heated.
So, in what circuit would this be used.
Thanks, Mikek
Michael Black
I parted out a flat screen TV, I pulled an inductor off a board. The inductor
is about 3" long and an inch in diameter. It is wound with a litz type wire
I'm curious, what was the use of this coil. It seemed to carry a pretty
heavy current, because it was mounted with 4 pins on each end and all four
pins were connected to the litz. Also the solder joints to all the pins were
over heated.
Thanks, Mikek
The trick is to keep the boards intact until you need the parts, then the
context helps reveal information about the part.
Michael
amdx
the context helps reveal information about the part.
Michael
I have boxes of boards, I'm just curious about the use of this
physically large inductor.
Mikek
Michael Black
I have boxes of boards, I'm just curious about the use of this physically
large inductor.
Mikek
But if you have the rest of the board, that might give an indication.
WHere it sits might be a a broad giveaway, to narrow things down.
Michael
