Floppy drive broken in HP4145B Parameter Analyzer
sunshine
we are still using the obsolete HP4145B Parameter Analyzer. It's a
wonderful piece of equipment and it does the job.
Although it is hooked up to GPIB, it still needs the floppy drive with
a bootdisk. Unfortunately the floppy drive broke and Agilent does not
have any spare parts. Even though it is 3.5" it is not compatible with
the common PC floppy drives. Any idea to work around this (except
buying new equipment)?
Any comments are welcome.
David
AJ
Suggest contacting HP directly and ask if they have a part source or a
viable alternative that will be fiscally acceptable.
Michael A. Terrell
HP makes personal computers. Agilent was spun off as a test
equipment company a LONG time ago.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
Michael A. Terrell
sunshine said:
Are there any OEM markings on the bad floppy drive? HP/Agilent may
not have been the only one to use that drive.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
Bob Pownall
You _might_ be able to cannibalize a 3.5" floppy out of another piece of
HP gear of similar vintage. It wouldn't surprise me at all if the
floppies were identical, or at least compatible.
Bob Pownall
Bob Pownall
Also, there was a related thread in the sci.engr.semiconductors group
about a year ago.
Re: hp 4145A and 4145B semiconductor parametric analyzers
OP: Winfield Hill
Date: 8/4/2006
You might be able to come up with some useful information there. Heck,
a post to sci.engr.semiconductors might be worth a shot.
Bob Pownall
Andrew
sunshine said:
David
Try a floppy disc from an old ie mid 80's computer, HP9121 floppy drive
(there are a series of these GPIB connected floppys) HP150 computer etc.
Andrew
Michael Black
Of course, it makes sense to figure out why the drives are different.
I once got some IBM 3.5" drives that were completely standard, except
the edge connector had 4 more contacts, for the power supply. It
was really easy to use them, I just had to fix up a suitable connector.
But of course, there were lots of runners up in the 3.5" market, and if
these are of that type, then that is likely more complicated. But
even then, it would depend on the drive.
Michael
F
Franc Zabkar
David
I once modified the floppy drive interface in a Commodore Amiga to
accommodate a PC FDD. The differences in that particular case were the
Ready and Diskchange pins (2 & 34).
Maybe yours has a Shugart interface (2nd table):
http://pinouts.ru/Storage/InternalDisk_pinout.shtml
The first table is for a standard IBM FDD.
If you are lucky, and the differences are in the Ready and Diskchange
pins, then you *may* be able to find a FDD that can be jumpered for
either interface.
Otherwise this simple circuit worked for me:
http://groups.google.com/group/comp.sys.amiga/msg/6e89eb6a0986e1ff?hl=en&
- Franc Zabkar
H
HapticZ
probably just a common older 750kb single sided 3.5 inch drive.
tear it apart, extract the floppy drive and hack in an ebay unit from some
surplus dealer of seller.
that actually may be harder to find since it is "dated"
W
whit3rd
we are still using the obsolete HP4145B Parameter Analyzer. ... it still needs the floppy drive with
Some HP equipment used a controller board with odd connector, under a
standard
Sony mechanism. Early Macintosh (800k) floppy disks were similar in
the
mechanisms, but not the controllers. You can find a similar SONY part
and
swap the controllers. Maybe.
Mark Zenier
The first Sony 3-1/2 inch drives ran at 600 RPM, (so they had the same
data rate as an 8 inch drive). NEC did a special version of the '765
floppy controller chip for them.
Mark Zenier [email protected]
Googleproofaddress(account:mzenier provider:eskimo domain:com)
JW
They were double-sided double-density drives. The published capacity was
630Kbytes.
sunshine
Hi there,
I opened the box and found that the floppy drive is a Sony MP-F52W-20
drive. I tried to find such a used drive on ebay and so on but it
seems very challenging Does anyone know a good website were you can
look up compatibility with other/newer floppy drives?
Thanks!
David
James Sweet
sunshine said:
Hi there,
Thanks!
David
Most floppy drives are electrically identical, there's not really anything
in the way of intelligence in the drive. Assuming it has a standard 34 pin
interface cable, I'd try plugging in a generic PC drive and see what
happens.
F
Franc Zabkar
Hi there,
Thanks!
David
The prognosis doesn't look good:
http://www.hpmuseum.org/cgi-sys/cgiwrap/hpmuseum/archv012.cgi?read=32300
It looks like yours is a 600 RPM drive. There is a pinout at the
bottom of the page.
- Franc Zabkar
Gerhard Hoffmann
happens.
I tried that some years ago with the Sony drive in a 16500A.
It did not work.
regards, Gerhard
carneyke
It did not work.
regards, Gerhard
I used to get some working by cleaning the mechanisms with alchohol
(head cleaner) and lubricating the mechaism with an oil that creeps.
Clean the heads too. I've seen a sewing machine mechanic use a mixture
of Isopropyl and Automatic Transmission fluid. He had a squirt bottle
with a 50 / 50 blend.
iComp
Nov 19, 2009
NEW replacement drives available
hey folks,
we have developed a replacement drive for the HP4145B. We're using high-quality TEAC mechanisms and re-fit them with new electronics in our factory. The behaviour is just like the original Sony MP-F52W-20 drive with only one difference: The LED is always ON.
You can continue to use the old disks. No need to re-format them, no need to make modifications to the electronics of your valuable measurement device (as opposed to other repair methods). Check out item#170409173061 of a well-known site for pictures. Use the contact form of our site icomp.de if you have questions about the drive replacement.
Jens
