Fluorescent E-lamps interfere with my wireless intercoms.
Stan Hilliard
In my home, I have switched some of my incandescent light bulbs to
Fluorescent E-lamps like GE FLE26HT3/2/SW. They apparently work use a
"high frequency or RF magnetic field to create a time varying electric
field which in turn drives a discharge which is very similar to the
discharge in an ordinary fluorescent lamp."
I also have Westinghouse wireless intercoms WHI-4C which work through
the household wiring. I use them to communicate between basement,
first floor, and second floor. They have four frequency settings: 230,
260, 290, 200KHz. I have them set to 260KHz.
Some of intercoms fail to work, which seems to be related to being
plugged onto the same circuit as an E-lamp. When I switch the E-lamp
bulb to an incandescent one the intercom works.
Is there any way to make E-lamps compatible with the wireless
intercoms?
Advice will be appreciated, Stan Hilliard
Jerry G.
You should use a completely different circuit for both, and maybe they may
not clash. The harmonics from the E-Lamps are too close to that of the
intercom. The other solution is to get a much more expensive intercom system
that works in the UHF bands, if you want wireless. The most reliable
intercoms are wired station to station.
Greetings,
Jerry Greenberg GLG Technologies GLG
WebPage http://www.zoom-one.com
Electronics http://www.zoom-one.com/electron.htm
intercoms?
