FM transmitter does not work on breadboard
chriswilliams
I have armed an FM transmitter on breadboard but for some reason it
does not work. I have checked wiring and components and all seems to
be OK.
Thanks in advance for any comment
BobG
be OK.
'Armed' is a funny word to use. Like 'Cocked'... like you have a static
hi or lo level on the tx line. You need to hook it to a TTL level
serial port sending ASCII 'U' over and over at a slow baud rate like
1200 baud. Should be able to see stuff coming out of receiver at same
rate!
Christopher
Hello Chris,
be OK.
By breadboard you mean one of those white plug-in proto boards? One
area of trouble I found is the many rows of plug in contacts behave
like 5 pf capacitors shorting out the RF. Use a generic copper pad
perf board and solder.
Good Luck,
Christopher
Temecula CA.USA
http://www.oldtemecula.com
Eeyore
be OK.
What style of RF construction did you use ?
Graham
chriswilliams
It's a simple FM transmitter with three transistors and an oscillator.
Don Bowey
be OK.
All of your wires for the frequency determining parts are too long.
Tom Biasi
And the board makes capacitors. RF on proto boards, a real nightmare.
Tom
