free pic programmer
alismans
I am trying to use the programmer from
http://members.aon.at/electronics/pic/picpgm/index.html
I have built the circuit
picpgm_cable according to the diagram. I have used a
74LS04 instead of 74ALS05 because this is what was
available. I then run the software WinPicPgm and on
the status line at the bottom there is a message
"No pic programmer found".
Can you help me?
thanks!!
Lord Garth
Can you help me?
thanks!!
At a glance I found this:
"A driver which is necessary to access the parallel port under Windows 2k/XP
is included and loaded automatically by the programmer software (no user
interaction necessary). "
It seems as if your driver isn't loading, look for it in your task manager.
Further, is your
parallel port on 0378h or one of the other two standard addresses?
Is your motherboard BIOS set to use the port as ECP ?
Lord Garth
Can you help me?
thanks!!
It looks like they assume you know to connect 5 volts and ground
to the 74ALS04...did you power the inverter? It works best when
power is present!
mike
Can you help me?
thanks!!
My apple pie recipe calls for apples. But I used tomatoes because
that was what was available. How come my apple pie doesn't taste right???
The first step in making any circuit work is to use the correct part.
If you can't us the correct part, at least use a COMATIBLE one.
The '04 is trashing your return data path.
mike
Return address is VALID but some sites block emails
with links. Delete this sig when replying.
Wanted, PCMCIA SCSI Card for HP m820 CDRW.
FS 500MHz Tek DSOscilloscope TDS540 Make Offer
Wanted, 12.1" LCD for Gateway Solo 5300. Samsung LT121SU-121
Wanted 12" LCD for Compaq Armada 7770MT.
Bunch of stuff For Sale and Wanted at the link below.
MAKE THE OBVIOUS CHANGES TO THE LINK
ht<removethis>tp://www.geocities.com/SiliconValley/Monitor/4710/
R. Steve Walz
They are totally different parts, it won't work without the '05.
The '05 is open-collector, totally different.
Can you help me?
thanks!!
-Steve
Lord Garth
Wow! That one is way old Steve....are you just getting it?
Byron A Jeff
Mucho snippage...
I note ALSO that nobody gave the right answer, are you guys slipping?
Steve,
I took Mike's answer as the correct one. To quote
"My apple pie recipe calls for apples. But I used tomatoes because
If you can't us the correct part, at least use a COMATIBLE (sic) one.
The '04 is trashing your return data path."
That's why I didn't bother to answer.
BAJ
Lord Garth
I'm up to my butt in alligators right now too...I will be traveling 200
miles
to the job site Monday at 4:30 A.M. Lets hope the phone guy is on time as
they don't like me climbing their poles!
Lord Garth
The guy never got back to me about the use of a PCB or anything else.
I would have suggested some other O.C. component but I really haven't
given it any thought.
R. Steve Walz
Byron said:
Mucho snippage...
Steve,
BAJ
But only a grade of B for that.
"But Byron, what's wrong, they're both inverters??!!"
-Steve
