frequency meter
kdor
Aug 15, 2010
4
I don't have an oscciliscope, is there any other accurate means of obtaining a signals
frequency?
Know anything about residual frequency, or how to achieve anti-gravity?
I also wired up an invention that takes oily,contaminated waste water and through a
process,recycles the water and separates all dirt,fuel/oils,ect. For use at any company
that has ,operates,or uses vehicle/machinery wash racks.Complies w/EPA,local laws.
If any interest,I could share design schematics.
Kevin Weddle
Feb 23, 2004
1,620
You can guess as to an approximate frequency range using other measurement devices. But an oscilloscope or other frequency measuring device is required at higher frequencies and lower amplitudes.
Kevin Weddle
Feb 23, 2004
1,620
The signal can be converted to a clock signal with an opamp. A counter will set the last bit after a number of clock pulses. This bit can be used to power an LED, which will flash. An analog voltmeter or digital voltmeter can measure AC up to a maximum frequency and amplitude across a capacitor. But it would not be very accurate.
