frequency terminologies
  • Thread starter zouhaier ghorbel
  • Start date
Z
zouhaier ghorbel
Hi
someone can tell me waht's the difference between "frequency corner" and
"center frequency"
Thank you for your help.
Paul Burridge
Hi
"center frequency"
If you imagine an elongated triaglular shape, pointed end upward, the
centre frequency would correspond to a vertical line dropping down
through the apex of the triangle. Now imagine someone comes along and
slices off the top of the apex. There's now a flat top with two sides
which suddenly drop away quickly. These 'shoulders' are analogous to
the corner frequencies. The drop on the right is the upper corner
frequency and the drop on the left is the lower corner frequency. The
centre frequency remains unchanged, being the mid-way point between
the corners. Establishing the precise location of a corner frequency
in the case of a genuine frequency peak is a little more difficult -
but not much.
Easier to explain with a diagram, really.
Active8
Can I hang a weight on it and use it for a metronome or should I
wait for that prick with the apex cutter to finish up?
But Mr. Wizard, what if it's a high or low pass filter?
Those are passband skirts. The corners are the corners.
The
the corners.
Only geometrically when plotted on a log scale. Numerically, a band
pass filter having -3dB points of say, 100 MHz and 125 MHz has a
center frequency of 111.8 MHz, not 112 MHz.
but not much.
How 'bout an example? My BS detector is going off full-tilt here.
Without a stinkin' diagram.
Active8
Oh yeah. Metronomes are upside-down pendulums.
Never mind.
Paul Burridge
Then you will no doubt be able to assist the OP with a more accurate
explanation, then.
Indeed. By all means let's hear it....
Active8
explanation, then.
"Establishing the precise location of a corner frequency
but not much."
I was hoping to find out what the hell you meant by the above
statement. How you would nail down the corners with and without a
"genuine" peak. I don't even see where that constraint even figures
in.
H
hannibal
i get really confused with frequencies terminologies.
actually i am working on spreadsheet for Tx so first i am trying to get
familiar with terminologies so i strart with taking a look to Rx spreadsheet
that's alrady done by someone else.
In excel Rx spreadsheet, sometime:
Device frequency corner= Center Frequency+ 1/2 (Device3dB Bandwidth at
output)
and sometime:
Device frequency corner= Center Frequency+ Device3dB Bandwidth at output
i don't know why?
please advice
John Woodgate
I read in sci.electronics.design that hannibal <[email protected]>
wrote (in <[email protected]>) about 'frequency terminologies',
i get really confused with frequencies terminologies. actually i am
working on spreadsheet for Tx so first i am trying to get familiar with
output)
That's right, except it should be 'Device corner frequency' or even
'Device upper corner frequency', if it's a band-pass filter, because
there is another -3 dB frequency below the centre frequency. The -3 dB
frequency is regarded as the edge of the pass-band, where the response
'turns the corner' to its steep decrease.
and sometime:
output
That what we experienced engineers know as an 'error'.
Paul Burridge
but not much."
Well, *with* a genuine peak, the corners are, IIRC the -3db points
either side. Without a peak? What, you mean like as in the type of
'double-hunched' response you typically get with overcoupling two
tuned circuits? Yes, that's trickier. Hell, whatever, by all means let
the OP have *your* definition, Mike. *I* might learn something as
well. God knows I can use it!
John Fields
Hi
"center frequency"
Me can.
If you have a radio or a stereo with what ISTR is called a "parametric
equalizer", if you turn the bass and the treble down, and leave the
midrange up, then the midrange frequency which will come in the loudest
will be the center frequency.
If you turn the bass down and leave everything else the same, then the
frequency where the bass will be half as loud as everything else will be
the corner frequency, and if you turn the treble down and leave
everything else the same, the frequency where the treble will be half as
loud as everything else will be the corner frequency.
Also, if you turn the midrange down while leaving everything else the
same, the frequency which will be the least loud will be the center
frequency.
Active8
But in a symetric filter, the center freq is the geometric mean of
the upper and lower cutoff freqs, not the arithmetic mean.
John Woodgate
I read in sci.electronics.design that Active8 <mTHISREMOVEcolasono@earth
But in a symetric filter, the center freq is the geometric mean of the
Yes, but the difference is very often indeed quite negligible. We are
talking '-3 dB', not '-3.000000 dB'. Consider a single-tuned circuit at
500 kHz, with a -3 dB bandwidth of 10 kHz. Sqrt(495 x 505) = 499.97....
kHz.
Active8
I thought maybe you meant that a genuine peak was a bp with such a
high Q that you couldn't see that flat top without zooming in and
therefore couldn't find the corners.
either side.
No. The corners are the estimates of those points. They're found by
drawing lines along the passband skirts that approximates a
constant straight line rolloff and another line along the top of
the passband. The intersections are the corners. The steeper the
skirts, the more closely the corners approximate the -3dB freqs AKA
cutoff freqs.
You were off to a good start. You at least drew a verbal picture.
You f'd me up with that "genuine" peak stuff. I thought you read
something somewhere that I just didn't run into myself. Plus I was
f'ing with you to test the aforementioned BS factor. So I threw out
the question, "WTF"?
I was going to get all masochistic and post some derivations of the
attenuation curve of simple filters and try to show where the
cutoff freqs are, but I don't think that'll help the OP at this
point.
One thing that might help, however is to explain this -3dB stuff.
-3dB bandwith - the bandwith of the filter from the lower to upper
frequency points where the response is 3dB below the level of the
passband response.
Furthermore one can define another bandwidth like say -40dB BW
which gives an indication of the steepness of the passband skirts.
Active8
kHz.
Sure. Maybe it's just a technicality. I posted this triviality
twice though since in SED, I think we'd rather be accurate.
John Woodgate
You'll get an 'irritating pedantry warning' from Genome if you are not
careful. (;-)
Take 10% bandwidth at 500 kHz; the geometric centre is still only 2.5
kHz lower than the arithmetic. There is a self-compensating effect: as
the fractional bandwidth increases, the difference between the means
also increases, but it matters less as well.
Paul Burridge
passband response.
Then divide the latter by the former to get the "shape factor"? I
think it's called that but I may be misremembering the correct term.
It has been known. :)
Active8
Yeah. you can do that, too. Shape Factor.
