Fridge/Freezer fault, warm beer Argh!!!!!
Ricardo
The fridge part of my parents Hotpoint fridge freezer has packed up (model
no. 8590).
See: http://www.gdainfosite.com/pdf/service/HB8591.pdf
My Dad asked me if I could test the fridge thermostat, simple I thought!
But when I got access to it I couldn't fathom it out. The freezer thermostat
was as I expected with a calpillary tube and electrical conections. But the
fridge stat just below it was operated by a long plastic rod, and although
it had a calpillary tube I couldn't see and electrical conections. I
couldn't understand it? How does it tell the compressor when to turn on and
off?
Some pointers or advice in diagnosing the problem would be greatly
appreciated.
BigWallop
Ricardo said:
no. 8590).
off?
appreciated.
It sounds like a single compressor unit, so the 'stats will be split between the two compartments, but
still control the one compressor.
Make sure that the drainage system under the cooling panel in the fridge box is clear and clean. It is
like a rainwater gutter on the side of a roof. It should have a drain off hole in the middle.
Make sure that the 'stat setting knob in the fridge box hasn't been nudged to a higher setting. If the
fridge is full of goodies, then make sure that nothing hot has been placed under other bits and pieces,
and that the cooling panel isn't being blocked by anything, or even has paper stuck to it.
http://www.basecuritysystems.no-ip.com
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.555 / Virus Database: 347 - Release Date: 23/12/03
Ricardo
I will do, I'm going back round there Boxing Day.
Anyone else got any suggestions?
Jon Elson
Ricardo said:
no. 8590).
off?
appreciated.
The frost-free units have a single cooling coil between the refrigieration
and freezing compartments. A fan, or fans, blows cold air around as
needed. The usual arrangement on the older units was a thermostat for
one compartment, and a damper or louver to regulate air flow to the
other compartment. If the refrigration compartment is too warm, then
something must be blocking the cold air from getting to it. Can you
hear the fan running? Is air coming out of the vents?
It could have an ice buildup that is blocking the air passage. These
things typically have a big radiant heater that periodically defrosts
the cooling coils, and very small heaters that prevent condensation
on some of the partitions between the compartments. If these heaters
fail, it can cause condensation to form, and eventually freeze, blocking
the air flow. It is also possible the mechanical thermostat has failed or
has become jammed. There is most likely a louver or damper in the compartment
with the cooling coils connected to the long plastic rod you mention.
Jon
Ricardo
Your spot on with your advice Jon. Although I haven't been back round there
yet I've been giving it some thought.
You're right about the paddle on the fridge stat, and I remember now seeing
the vent (obviously from the freezer compartment) that it must cover and
uncover.
I'd left the vent uncovered yesterday because I never put the stat back. I
know no cold air was coming through it. Tomorrow (as you advise) I will
check that the air passage between the fridge and freezer is clear and
whether the circulating fan is working.
Thanks again for that, I'll give you feedback when I've had another look at
it tomorrow.
