FSK modulator/demodulator
rasmusms
Does anyone have a idea for a FSK modulator and demodulator witch is
frequency stable at a wide temperature range (-40 - 80) celsius
degrees. The carieer frequency should be around 1-2Mhz
Allan Herriman
What stability do you require? +/- a few percent , or +/- a few ppm?
If the latter, a DSP based modulator and demodulator clocked from a
TXCO could work.
Regards,
Allan
rasmusms
probably about +/- 1000ppm. It depends on how fare the 2 frequency are
apart.
TXCO could work.
Seems as a expensive solution
Regards,
Rasmus
Rene Tschaggelar
A stability of 0.1% is not doable with pure analog.
Did you have a look at a DDS such as the AD9833 ?
Rene
Rene Tschaggelar
apart.
They need to be at least the baudrate apart. Better a bit more.
rasmusms
It is to expencive
I thought so. So they need to be a least about 300kHz apart (min.
200kbps)
It doesn't need to be all analog
Rene Tschaggelar
rasmusms wrote
What stability do you require? +/- a few percent , or +/- a fe ppm
probably about +/- 1000ppm. It depends on how fare the 2 frequenc ar
apart
Allan Herriman
It is to expencive
200kbps)
If there is a good balance of 0s and 1s in the bitstream you are
transmitting, then it's fairly easy to use a PLL to make the (analog)
modulator frequency stability as good as that of a reference crystal.
The PLL will need a fairly low loop bandwidth to avoid causing
excessive baseline wander.
The PLL will also need a fairly low comparison frequency to avoid the
problem that occurs when the phase modulation on the output (due to
the FSK) scaled by the feedback divider exceeds +/- 2 pi radians,
which is the linear range of the phase detector.
You might need to use a scrambler to ensure a good balance of 0 and 1.
Regards,
Allan
