Lathe_Biosas
- Jan 1, 1970
- 0
Hi
With a GAL 16v8 I would like to programm some kind of decoder (8
inputs, 7 outputs) with the following code:
TABLE input => output {
'b'00000000 => 'b'1010000;
'b'111111111=>'b'1010000;
the 7 output values are defined in [40 .. 80] and the inputs in [0 ..
255]
When compiling with wincupl I get the following error:
-excessive number of product tems: a1, a2, a3
a0-a6: are the outputs coded to pins 12-18 respective
Is there some type of limitation that using TABLE does not aloud 255
values to be coded?
Any hint how to solve the problem?
Best Regards
255]
values to be coded?
Best Regards
