Golf trolley motor & battery repair
JT101
Mar 14, 2013
6
Hi everyone.
I'm a mechanical engineer, so I can work things out, but I don't have an inherent knowledge of electrical or electronics, so I hope someone can help me out.
The item in question is an electric assist golf trolley for carrying a golf bag.
I have the cable as attached in the photo which needs repair. The red and black ends attach to the positive and negative on a lead acid leisure battery (12V 36Ah) I have two questions
1) I need to replace the 6mm ring connectors. But the ones I've looked at are rated at an amperage. Some are 5 amps, some 30amps. Which should I choose? Is it related to the 36Ah rating of the battery?
2) Can anyone identify the three pin black connector that goes in the Linix motor? It has a half moon notch cut out of it.
Many thanks
GreenGiant
Feb 9, 2012
842
Look at the rating of the fuse that is in line with the positive cable, if its 5 or less you can use the 5A rated ones, but if its over that (say 7 or 10) youll need to get higher rated ones, by rights you should use higher rated terminals than the fuse.
This should be the plug
JT101
Mar 14, 2013
6
Great, thanks.
Well it had a number 30 written on the fuse, so I got some 30amp rated terminals (the highest I could buy from Halfords).
I couldn't find the specs of this golf trolley, but similar ones seem to have motors about 180 - 200W, with 12V battery's.
So 180 / 12 = 15Amps. So 30 should cover all bases.
Now how about the other end of the cable. The three pin connector. Anyone got any ideas?
Surprise surprise, the guys in Maplin didn't have a scooby
KJ6EAD
Aug 13, 2011
1,114
The link to the connector is in GreenGiant's post.
JT101
Mar 14, 2013
6
the other cable
Now I've discovered the other controller cable has broken. Some of the wires have come loose and I don't know which way they go back.
Can anyone either help me with a colour label diagram of this connector, or tell me what connector it is so I can buy a new one?
JT101
Mar 14, 2013
6
Resolution
Well, I would have ideally like to have known what the cables were. Unfortunately green giant's link just gives me a place to buy a new one, but doesn't tell me what it is. Anyway, I repaired it by figuring out the wiring configuration for the controller cable. See photo
