Skandalos
- Jan 1, 1970
- 0
Good thing used to be totally flawless but a couple of weeks ago the
color Blue started fritzing out. When I switch the monitor on all colors
are alright but after a minute or so the blue goes away. Somtimes coming
back later for a couple of seconds and leaving again.
Since Ive had the same problem before with another monitor which I could
repair by finding a few broken solder joints and resoldering them I also
tried to repair this one. No luck so far.
On the back side of the monitor is a circuit board where obviously the
colors are processed since the leads from the vga connector end up here.
Tried to find the bad guy on this board using a wooden stick pushing
here and there, tried to apply coolant spray, carefully first, then
emptying the hole bottle, but none of this could cause the slightest
flickering of the blue.
I tried to guess which way the blue signal goes and randomly resoldered
lots of joints, still no luck.
Last thing I did was to compare the voltages (DC) at certain points on
the ways of the color signals. First at the connectors where the fresh
VGA signals come in:
Red - Red Gnd = 192mV
Green - Green Gnd = 191mV
Blue - Blue Gnd = 232mV
Then at the rear end of the signal processing where all the final stuff
enters the tube.
Red - Gnd = 91V
Green - Gnd = 92V
Blue - Gnd = 123V
Im no electronics pro and so I havent the slightest idea if these
numbers are of any use.
Any hints would be appreciated! It is a great monitor and other than the
missing blue everything else is still in perfect condition, not bad for
a 8 year old monitor which has been intensely used.
enters the tube.
Red - Gnd = 91V
Green - Gnd = 92V
Blue - Gnd = 123V
