Morse said:
ian said:
My old but useful I/O magic CD/DVD burner has developed a hangup when
opening the door.
Although I see no physical obstructions, several months ago it began
opening only a few mm, requiring manual assistance.
Now, it is not even giving me the few mms.
I can use a paper clip but I tend to encounter a fast rotating CD
which I
assume is not good for the disc.
Drawer closes as normal with a slight tap.
I'm guessing this could be a lubrication issue but would not have a
good
idea where to start.
Short of buying a new unit [cheap enough - but no satisfaction in
doing
that] any suggestions on where to begin would be appreciated.
Thank you.
Remove -NOSPAM- to contact me.
Open it up and see if the drawer is belt operated, someone else
mentioned
lube - you don't want any on the belt and you have to be careful what
lube
you use, some of the plastic parts may be ABS which goes brittle and
disintegrates if exposed to hydrocarbon lube - silicone grease is safe
for
most plastics.
Heaven knows why they still make belt driven CDRom/DVDRom drawers, it's
completely unnecessary and decreases reliability. The only reason I can
think of that they use them is to introduce some slippage in the event
of the drawer jamming, especially by small fingers, like a cheapo clutch
mechanism.
I recently saw one advertised online which stated it was belt driven in
the spec, like people are supposed to be impressed! I don't trust
anything with belts to last too long, unless it's those tough,
non-stretchy toothed ones sometimes seen in camcorders and the like.
My beloved Aiwa AD-F500 cassette deck would still be going strong if it
wasn't for the damn belts.
Morse
I know what you mean about belts going bad in cassette tape decks.
The belts which drive the cassette decks in my Aiwa CX-NA888 bookshelf
digital stereo system (bought new seven years ago) are starting to
go--one deck doesn't work now due to a bad belt, I think. I read on
another site that these belts are very prone to failure after a period
of time, but at the same time it was stated that the left deck
[playback only] is much more prone to belt failures than the right deck
[record/playback]. The fact that the belts are starting to fail in my
system doesn't especially bother me, as I rip my CDs and cassettes into
my computer (the latter using Audacity open-source audio editor
software, the former using the CD ripping feature of Winamp). I use an
external cassette player to feed the cassette audio into the computer,
then I listen to the music as mp3 files. (I rarely listen to local FM
these days, preferring either AOL Radio with XM or an easy-listening
station on Winamp Radio called The Breeze, easy listening from Crown
Point, Indiana.) Makes loads of sense, considering that cassettes are
becoming obsolete, and CDs may not be too far behind; everyone these
days, so it seems anyhow, is listening to music downloaded from the
Internet on those little belt-clip players like the SanDisk Sansa, et
al. as mp3s. Heck, even today's newest cars don't have AM/FM/cassette
receivers anymore. Almost all new cars have FM/XM satellite radio/CD
players available, sometimes with XM radio as an option, and who knows,
maybe next year or even sooner most vehicles may have XM/FM/mp3
receivers that can download mp3s from the Internet on the fly, while
the driver is traveling down an interstate highway at 60 mph, no doubt.
BTW, it should be possible even today to find the belts for your
Aiwa tape deck. I'm not familiar with the AD-F500 cassette deck, but
the belts should still be available if you do a bit of looking. Have
you tried a local repair shop? If I were a betting man (I'm not), I
would be willing to bet that a local shop may be able to find the belts
your deck uses. May cost you a bit, but if the belts are all that's
wrong with the machine it will be worth it. It sounds to me like you
like your deck quite a bit and would like to have it running again.
Jeff Strieble, WB8NHV (email addy not shown to deter spammers)
Fairport Harbor, Ohio USA (33 miles east of Cleveland, near the south
shore of Lake Erie)
